my heater will only work on the windscreen and setting 4, 1 2 3 will not work the resister is in perfect working order. the relay makes a noise on the above two setting but not on 1 2 3 as anybody get any idear thanks.
loads of posts on that mate look down in trouble shooting easy repair as well bet you have wet passenger foot well as well !!
Don't know why you posted the same question as yesterday, but the question I posted back to you still applies
http://www.vectra-c.com/forum/showthread.php?t=52056
"How did you check the resistor? The classic signs of a failed resistor is that the speed will only work on setting 4. "
sent it off to be repaired sent it back saying it was ok and gave me afull refund also fited a new one also the garage said it was ok when they had a quick look.
would not think you can have a quick look at a thermal fuse are you sure you have the right part? white plastic then about 75 cms wrapped in tape and two prongs and a wire with a bulge on at the top
i now what a resister look like igot two off them and as i said before its not the resister they both work
thats good then so you know all about it guess you will know what you need next then !! word of advice I was just checking as its my time as well so a simple yes and electrician checked it out for me (or what ever)
gets expensive now though good luck do you have climate control or air conditioning?
just air conditioning also the light on the air circulation button don't come on
