Thread: 3.0 V6 Engine 'Rumble'
    Regular Member John Bishop's Avatar
    Oct 2010
    Default 3.0 V6 Engine 'Rumble'
    I have a 3.0 V6 estate and have noticed recently that sometimes when I stop at lights or in traffic the engine develops a very deep rumble sound and the car vibrates up and down a bit. No warning lights come on or anything but I have noticed the rev counter increases a bit but the engine speed appears to stay the same. Anyone got any ideas on what it is
    Aug 2010
    Antrim
    Engines tend to rumble a bit when they are turned on............
    Oct 2010
    Thanks for your words of wisdom Will
    Sodding Typical on Sea
    At times the loading on the engine does cause the idle to seem stressed but it will return to normal I noticed it with the engine when it was very cold from a start and all the heating and fans are on etc
    Oct 2010
    Thanks Derek
    The car is stationery and is bouncing up and down?!?
    What is the clutch like?
    What are the revs on idle?
    Could be the DPF doing a regen - it causes those symptoms...
    Oct 2010
    Clutch is fine and revs at idle are about 700
    Oct 2010
    It happened again today then the engine electronics light came on and it went into limp mode. Lost power and could only do about 30mph. Got to work and started it up later and it was fine but will keep you posted.
    Oct 2010
    What is a DPF Penfold? Sorry about my ignorance.
  1. Rumble and clunking
    By Gazza36 in forum Vectra C / Signum Troubleshooting
    Last Post: 17th July 2012, 20:28
  2. steering rumble
    By vectra3.2dave in forum Vectra C / Signum Car Chat
    Last Post: 20th July 2010, 21:13
  3. Rumble when changing up 1st - 2nd
    By Hobo in forum Vectra C / Signum Car Chat
    Last Post: 7th May 2010, 21:30
  4. front end rumble
    By prof1908 in forum Suspension, Wheels & Brakes
    Last Post: 30th April 2009, 13:38
  5. gearbox rumble
    By silky in forum Engine & Drivetrain
    Last Post: 5th April 2009, 09:55
