Thread: egr valve check
    nottingham
    Default egr valve check
    Can anybody tell me how you check if an egr valve needs changing i have cleaned mine every 6 months since ive owned it and its always very sooty i also have a judder if im on the motorway and then go to over take something so planting my foot and get juddering could this be egr related or something else. I do over 100 miles a day to work and back, car has done 82k and is a 1.9 cdti 120. Hope someone can shed light on this for me.
    Bristol
    Vehicle : CDTI 150
    Hi Daz,
    Could be the throttle body cct board needing a resolder; could be a sticky EGR have you cleaned the solenoid?
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    What are the markings on the plug mate?
    nottingham
    hi what is a cct board? how do i clean the solenoid? and what markings on which plug am i looking for? thank you for getting back to me
    Bristol
    Vehicle : CDTI 150
    Hi Daz,
    Within the throttle body (large assy bolted on to inlet manifold, pax side) there is a circuit (cct) board, the solder joints can break.
    The EGR solenoid can be cleaned by un bolting it it from the end of the EGR valve, then using a drill (3-5mm), makeing a hole in the plug end, within which you can insert a drift to knock the solenoid assy out. This process is explained within the Vec C website.
    http://www.vectra-c.com/forum/showth...45#post1338145 (Throttle body)
    nottingham
    Thanks mate ill look into both of those and see how it goes
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    As you do 100 miles a day if your ever this way i can give you some pointers!, close to j10 m42.
    nottingham
    hi wizard i used to live in tamworth how near to j10 are you? and i will defo come and get some advice off you am in tamworth most weekends infact are there tomorrow as parents live in tamworth your help would be most appreciated
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Could be throttle body related, if your cleaning the egr regular it should be ok, but a FULL clean as shown in the how 2 is a good idea, also have you thought about the semi blanking gaskets, this will reduce the soot down to nill virtually. pm'd.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    You might have actually escaped the throttle problem tbh. I think it only affects 2004 and 2005 CDTI's.
    Gazza4
  1. Wheels refurbed, Check - Car Buffed and Polished, Check! !
    By messermitch in forum Quick Photo Album
    Last Post: 18th July 2012, 23:18
  2. Valve Clearance check with Cambelt change
    By LeeU in forum Y & Z30DT Specific
    Last Post: 6th April 2012, 00:51
  3. For Sale: RAC Car Data Check (similar to HPI Check) - £10.00
    Last Post: 29th July 2011, 08:49
  4. check these egr valve pics out! Seems i have a missing part!
    By richiem in forum Engine & Drivetrain
    Last Post: 20th September 2010, 19:07
  5. Swirl Valve Check-HOW??
    By Vaux-Man-G in forum Vectra C / Signum Car Chat
    Last Post: 13th July 2009, 19:26
