Thread: New problem.
    Jan 2010
    Perkinsville, County Durham
    Trim : Sri nav
    Engine : Z19dth
    Default New problem.
    The car (1.9cdti 150) broke down on me yesterday. Loadsa noise and no power.
    Got towed to a garage and popped in today to find out the crack.
    Looks like i've lost some tension off the cambelt. The fuel pump pulley looks loose (as if the pump has broken inside). And possibly jumped a tooth.
    They are going to fit a cambelt kit and get it timed up, then they'll be able to see if the fuel pump is bust.
    Anyone had similar experience?
    Ironically i was on my way to the garage to book in for a service, Mot, cambelt and waterpump kit.
    Jan 2010
    Trim : Sri nav
    Engine : Z19dth
    Bump. Anyone heard of this one?
    Regular Member mozzer99's Avatar
    bristol
    Recently there have been several cases of the fuel pump pulley being cracked - maybe that is why yours appears loose - otherwise cam belt failure is almost always the water pump failing and throwing the belt off or at least jumping teeth.
    Not much you can do until it's apart, fortunately quite easy to do. As it has jumped it is important that the garage use timing tools as it is easy to be one tooth out when refitting.
    Jan 2010
    Trim : Sri nav
    Engine : Z19dth
    Yeah, that's what they're waiting for, the cam timing tool. I'll ask them to check the fuel pump pulley for cracks tomorrow when they're open. Cheers mozzer.
  1. Problem...? Vectra SXI...problem with starting after filling with fuel?
    Last Post: 21st October 2022, 12:25
  2. Rear Signum Light problem problem - help
  3. Wiper Electrical Problem? (Not sticking or cold weather problem)
  4. 1 problem sorted and 1 more problem arises
    Last Post: 4th April 2011, 13:03
  5. Bit of a problem, Need Help
    By vectrasri-j in forum Vectra C / Signum Car Chat
    Last Post: 18th January 2010, 19:21
