Results 1 to 10 of 11
Thread: Limp home mode
    Jan 2008
    llanddewi
    Angry Limp home mode
    Any thoughts please , car suddenly gone into limp home mode, max revs 3000 with no turbo, engine and spanner lights on.
    Not smoking or burning oil just no turbo and limited on revs.
    Have it booked into dealers tomorrow for diagnostics.
    Vectra c 1.9 diesel Automatic. 2004.
    Thanks Brian
    Jan 2010
    wirral
    DPF.........possibly, although I'm not 100% sure you would have one on a 2004, but quite possible if its an early CDTI. If they do get a DPF related DTC on the diagnostics, and the dealer recommends a new one, think carefully and explore other options!!
    A forced regen of the DPF should really be included in your hours labour charge/diagnostics fee
    Regular Member signum junkie's Avatar
    Edinburgh
    Sorry to hear m8. I had spanner light and limp mode happen four times on way to South of France in summer I sh*t myself. When I arrived I gave car a good looking over only to find it was a loose brake light bulb shorting the electrics. You never know m8 it may just be something silly. Good luck.
    Central Scotland
    Quote Originally Posted by bafoo View Post
    Should be, but wont be.
    Most VX stealers dont have the proper knowledge of TECH2 and certainly wont add 'extras' into a £75 +VAT scan.
    Personally, I'm getting fed up of Vauxhall technical guys being incompetent of using TECH2, telling customers "it cant be done".
    Jan 2008
    llanddewi
    Default update-limp home
    Thanks for all the suggestions, don't think car has a DPF.
    Took car to dealers this morning, Tech2 showed code P1109, Swirl acuator malfunction.
    Investigation showed that the arm was off the swirl vales on inlet manifold.
    Dealer charged me £ 20.68 including VAT for investigation and quoted £450 including VAT to fit a new inlet manifold.
    I am now off to the How2 section to see how to fix it.
    Will keep thread updated.
    Brian
    Nov 2010
    bristol
    I had the same thing on mine, could only do about 20mph home,found out an injector was blocked and needed flushing through
    Jan 2010
    wirral
    Quote Originally Posted by llanddewi View Post
    Brian
    Seems like a very reasonable price for a dealer, given that its a 3-4 hour job.
    I tried the D.I.Y fix for the swirl valve rod.......it did not work!!
    Jan 2008
    llanddewi
    Unhappy
    I have tried the £1 fix, the rubber did not stick to the plastic very well ,come apart with little effort. It was worth a try.
    Now getting quotes for new inlet manifold.
    Regular Member djr69uk's Avatar
    Midlands
    was the bar completely off? if it wasn't you can take it off completely and it might prevent P1109 - unless swirl valve 3 is sticking. obviously the only real fix is new manifold i'm afraid.
    Jan 2008
    llanddewi
    The bar was completly off. I will check to see if no.3 is free, the others are free to move.
  1. limp home mode
    By DAVIDD88 in forum Engine & Drivetrain
    Last Post: 22nd September 2012, 09:12
  2. Limp Home mode
    By Bredsticz in forum Engine & Drivetrain
    Last Post: 12th July 2012, 19:43
  3. limp home mode
    By fig in forum Engine & Drivetrain
    Last Post: 20th January 2010, 23:18
  4. CR2 going into limp home mode
    By plasma in forum Diesel Engine related
    Last Post: 17th April 2006, 20:45
