Thread: blue smoke on 1.9 cdti 150
    Regular Member big nath's Avatar
    Jan 2008
    Irthlingborough
    Default blue smoke on 1.9 cdti 150
    When the car is cold been siting for 4-5 hours starts up first time but straight after starting it runs a bit lumpey so blip the throttle and i get a puff of blue smoke from the back then she runs fine. Had the cambelt changed about 1 month ago and had the cat taken out from after flexi pipe as this was broken , Car is on 114000 miles and is a 2004 Hatchback.
    Any help would be great as need the car for work and not a good time of year for a large repair bill.....
    Wirral
    10 Post(s)
    Engine : 1.9CDTi
    Mileage : Lots
    It's just because of the miles the car has done. It'll be a little bit of oil seeping into the cylinders. Mine's a 2.2 diesel and on 141k, that coughs out a little blue smoke when it's started. Nothing to worry about unless you're getting big clouds.
    My mums Citroen C3 is terrible, puffing blue smoke all the way down the road and it's only on 31k miles.
    Jan 2008
    Irthlingborough
    Thanks for that it still runs up and down the M1 3 days a week just need to get the flywheel clutch done after Xmas.
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    My other half's 1.9cdti sri 150 (2005) puts a LARGE THICK blue cloud out on cold-start, but runs fine, oil level never drops, and it pulls really well. No smoke on warm / hot starts, or indeed innormal driving!
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    My mate had a similar problem on a totally different car. A Peugeot 306 2.0HDI.
    One of the injector was seized and just like your car, his spluttered on start-up, puffed a bit of blue smoke and ran fine after a blip of the throttle.
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Quote Originally Posted by tony-1977 View Post
    But my (2003) 2.2 DTi SRI never blue-smokes, it runs quieter, uses less diesel.... AND it's older!
    Regular Member Grimo72's Avatar
    Apr 2008
    Lincs
    mine did this,
    take off plastic engine cover, and ensure all ignition coil caps are pushed on a nd click in position
    i had a loose one, did this and all sorted
    worth a go ................
    Regular Member zafira's Avatar
    Aug 2010
    North of Norway
    Quote Originally Posted by big nath View Post
    Does your oil level sink between oil changes?
  1. Signum 1.9 cdti 150 Blue Smoke
    By Kyletasker in forum Engine & Drivetrain
    Last Post: 6th July 2012, 19:02
  2. Blue smoke sluggish 3.0 v6 cdti
    By Dam3dx in forum Engine & Drivetrain
    Last Post: 24th January 2012, 16:14
  3. SRI CDTI 150 Blue smoke on startup
    By sukyb in forum Engine & Drivetrain
    Last Post: 15th February 2011, 13:47
  4. SRI CDTI Blue smoke on startup
    Last Post: 8th February 2011, 12:01
  5. blue smoke 3.0 cdti signum help!!!
    By MARTIN KANE in forum Vectra C / Signum Car Chat
    Last Post: 11th June 2010, 21:03
1.9cdti blue smoke
blue smoke when i start my diesel astra 1.9 cdti
vectra cdti blue smoke
1.9 cdti blue smoke
vauxhall vectra 1.9 cdti blue smoke
vectra blue smoke
cdti blue smoke
zafira blue smoke
1.9 cdti blue smoke when warm
vectra diesel lots of blue smoke when warm
vauxhall vectra diesel blue smoke
vauxhall zafira 1.9 cdti blue smoke
