Likes Likes:  1
Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 23
Thread: Cold battery voltage? - 1.9CDTi 16v
  1. #11
    ireland
    12.1 when ignition on 11.6 when cranking over mine drops to 9.5/6,
    been having a few probs lately with starting,it takes a few more turns over than it used to,
    in my ignorance arent all car batteries 12v so how can they be expected to be any higher when no charging system is active
  2. #12
    preston
    I know i thought it a bit high but yep 14.1 before turnover - its always at between 13.5 and 14 as i check it once a week on the BC .... I've never actually done a multimeter reading.... all i'm bothered is that it stays in that region
    once it starts to drop then its getting changed...
  3. #13
    Jun 2006
    Kirkintilloch, Scotland
    Quote Originally Posted by mparks8590 View Post
    14.1v for initial charging voltage is spot on. 13.5 to 14.4 V is the "typical charging range" for a car battery.
    If the charging level falls below this is more likely to indicate a fault with with the charging system than with the battery.
    Dave
  4. #14
    Regular Member Marky's Avatar
    Jun 2006
    North West
    I have had the battery light a few times in the last week.
    Both the battery and the alternator were replaced in september last year.
    Looking at the voltage using test mode, its saying 13.2 with lights, demister and fan4 on.
    Once demister is off, fan to 3 and the engine has warmed up a bit it sits around 13.8v.
    Is this bad?
    I will check the voltage with just ignition on, engine off, and see what it reads.
    Two garages have checked that the alternator is charging ok in the last couple of months.
  5. #15
    Worcs/Staffs/Westmids (ish)
    Anything under 12.5v is no good. In fact my new Varta had a safety manual that stated not to connect (to a car) a battery that was at less than 12.5v.
  6. #16
    Sep 2009
    Audley STAFFS
    I had mine checked in the summer as it let me down, it stood outside a hotel for 5 days and on one night we sat in it with internal light on and radio on, for an hour (eating fish and chips), no start in the morning,, so when I got home had it tested at a tyre and battery place,, cold it was 12.2,, running with fans heater on 13.8v , it has never let me down again even in minus 10 degrees, not bad for a 2003 battery.
  7. #17
    Jun 2006
    North West
    Quote Originally Posted by Marky View Post
    OK this morning put the ignition on and nothing else. The car was saying 11.2v. Started the engine fine and put on the demister fan and sidelights only. Car was reading 13.7v.
    So from this I conclude that the Alternator is OK.
    But, the battery could be goosed or something is draining the battery a bit overnight.
    What should I check now?
    Should I double check the voltage figures from the test mode are correct with a multimeter connected to battery +ve and -ve??
    See what the voltage of the battery is last thing at night with the ignition off? To see what is being lost overnight??
  8. #18
    preston
    take battery off and multimeter it then and again in morning
  9. #19
    Regular Member kamar's Avatar
    bradford
    13.0 mine is when the temp was -5.. it starts fine so i assume its ok
  10. #20
    Regular Member ScotsDragon's Avatar
    Aug 2009
    Lost in Time and Space...
    Trim : SRI
    Engine : 1.9 CDTI 150
    Mileage : 50000
    Just tested mine,
    Outside temp -3.5 c
    12.54v Switched off
    10.93v while cranking
    14.56v when started
    TERMINATOR EYE IS GREEN
    All is good
  1. battery voltage advice
    By richje100 in forum Electrical & ICE (including SatNav)
    Last Post: 23rd January 2013, 14:39
  2. Vectra 1.9 CDTi 150 Alternator / battery voltage
    By trucklord in forum Electrical & ICE (including SatNav)
    Last Post: 11th October 2012, 10:06
  3. Battery Voltage
    By WeDesign in forum Electrical & ICE (including SatNav)
    Last Post: 8th January 2012, 17:14
  4. battery voltage
    By scottyd in forum Vectra C / Signum Car Chat
    Last Post: 17th July 2010, 22:13
  5. Op-Com ERROR: B3109 - Remote-Key 1 System Voltage Low Voltage
    By Jedi in forum Vectra C / Signum Troubleshooting
    Last Post: 30th June 2010, 18:17
battery voltage vectra test mode
correct voltage vectra 1.9.tdi
1.9 cdti battery running 12v
vectra c cc gts battery voltage
testmode readings 1.9cdti
