Results 1 to 10 of 23
Thread: Cold battery voltage? - 1.9CDTi 16v
    Regular Member djr69uk's Avatar
    Midlands
    Default Cold battery voltage? - 1.9CDTi 16v
    Would those with a 1.9CDTi and CD70 please go into test mode tomorrow and on the second page you have a voltage reading top right of screen. I'd be interested to know what they show. Mine was 11.5v this morning before I started her up - think this is a bit low.
    Please do this BEFORE you turn the car over. Thanks
    (test mode accessible on CD70 by pressing 'main' button, then pressing and holding 'settings' for 5 seconds. you'll hear a aircraft cabin style 'bong' then pressing 'BC' will cycle through screens of useful/useless data.)
    preston
    14.1v this morning
    Quote Originally Posted by mparks8590 View Post
    14.1v this morning
    With the engine running????? or before you started it??????
    Regular Member mitch's Avatar
    WIGSTON, LEICESTER, LE18
    Regular Member Reevo's Avatar
    Nov 2010
    Leicestershire
    Just done mine, been standing for 2 days tho. It reads 12.2, not sure if thats good, bad or ugly!?! Hope it helps anyway.
    Wirral
    10 Post(s)
    Engine : 1.9CDTi
    Mileage : Lots
    That does seem a little low. If your battery is on the way out, I remember reading something a while ago for leaving your lights and hi-beams on for half a minute or so before starting to 'wake up' the battery. I'll have to do mine with a multi-meter when I get round to it.
    Regular Member scottyd's Avatar
    paisley
    thats low get your charging system checked mate sounds like battery is goosed but you need to check alternator out put including amp(the important bit)
    Oct 2009
    Luton
    12.3V, temp -0.5 C. Terminator eye is green.
    If approx 14V when running with high electrical load (e.g main beam & fan no4 & rear demist) then generator is OK.
    Jun 2006
    Kirkintilloch, Scotland
    The following link has lots of info' with the table at 4.4.3 showing the relationship between a battery's state of charge and temperature.
    http://www.checkthatcar.com/carfaq4.asp
    Dave
    Midlands
    ...and this morning the display reported 11.4v before I turned it over.
    Left the car stationary but running and put front and rear demister on to clear screens. A minute later the battery light came on. I left it about 5 minutes and voltage had increased to 13.7v. As soon as I drove off it went back up to ~14.2v.
    Fairly confident the battery shouldn't have drained to just 11.4v overnight. Unless something is sapping power excessively overnight, then I'd say my battery was kapput!
  1. battery voltage advice
    By richje100 in forum Electrical & ICE (including SatNav)
    Last Post: 23rd January 2013, 14:39
  2. Vectra 1.9 CDTi 150 Alternator / battery voltage
    By trucklord in forum Electrical & ICE (including SatNav)
    Last Post: 11th October 2012, 10:06
  3. Battery Voltage
    By WeDesign in forum Electrical & ICE (including SatNav)
    Last Post: 8th January 2012, 17:14
  4. battery voltage
    By scottyd in forum Vectra C / Signum Car Chat
    Last Post: 17th July 2010, 22:13
  5. Op-Com ERROR: B3109 - Remote-Key 1 System Voltage Low Voltage
    By Jedi in forum Vectra C / Signum Troubleshooting
    Last Post: 30th June 2010, 18:17
battery voltage vectra test mode
correct voltage vectra 1.9.tdi
1.9 cdti battery running 12v
vectra c cc gts battery voltage
testmode readings 1.9cdti
