Thread: Light switch trouble
    Sep 2010
    Tranent
    confused Light switch trouble
    im trying to remove the light switch knob from my 2005 vectra sri.the instructions i was given were turn knob to 0 push firmly and turn clockwise and the switch should release only the switch seems to have slid deeper in and is now stuck in this position please help!!!!!!
    Jul 2009
    The Rift, Cardiff
    Brute force channeled through your finger tips.
    Or remove the lower dash trim. Or it might be easier to remove the silver/wood strip above the switch then the air vent, you might be able to push it from behind.
    Sep 2010
    Tranent
    does the silver strip just pop out
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 85000
    Take the side cover off the end of the dashboard, the bit you cant see when the door is closed, between the dashboard and the door. You will be able to see the back of the light switch through the holes. Take a screwdriver and place through one of the holes and on to the back of the switch, now while turning the knob on the light switch push from behind with the screwdriver and it will come out.
  1. Interior Light - 4th light switch blank ?
    By Woody in forum Electrical & ICE (including SatNav)
    Last Post: 12th November 2012, 23:44
  2. Light Switch
    By calbert07 in forum Electrical & ICE (including SatNav)
    Last Post: 24th January 2010, 23:29
  3. Fog Light Switch On
    By rob CDTI in forum Electrical & ICE (including SatNav)
    Last Post: 17th April 2006, 21:25
