hi guys, can anyone tell me if when my engine is cold ie. when the thermostat is closed, should the coolant still flow into the expansion tank? i dont think it should untill its hit 90 deg or whatever its set to, so think its knackered, ive looked for a new thermostat and temp sender but can only seem to find one for the vec b 2.2 dti, as far as im aware the vec c 2.2 dti uses the same motor as the vec b 2.2dti so im guessing it will also use the same themostat temp sender and housing, am i right![]()
