Thread: Kangeroo fuel
    West Midlands
    Default Kangeroo fuel
    Hi folks,
    My 2.0 Dti (03 plate) has suddenly begun to stutter. It bounces up the road like it's on kangeroo fuel.
    Initial thoughts were intercooler pipes as I'd had one go before and a large split was found in the LH one by the battery and a small one in the RH one.
    I've replaced both but the problem remains.
    When revving on the drive there seems to be a bit of a rattle coming from around the EGR area.
    Nothing lighting up on the dash - no spanners or anything!
    Just discovered that the fuel light had begun flashing for about 10 miles before being able to fill up and the problem started about half a mile afterwards. It's a well used fuel station with high volume fuel turnover, so I wouldn't imagine a problem with the fuel.
    Any suggestions very welcome!
    Jeff.
    West Midlands
    I should add that I meant no problem with the fuel 'quality'.
    Wirral
    10 Post(s)
    Engine : 1.9CDTi
    Mileage : Lots
    Could be water in the fuel, drain the fuel filter out and fit a new one. I think there's a nut to undo on the bottom of the canister to let the water out. If you were down to the flashing fuel light it basically means FEED ME NOW I'm almost empty.
    West Midlands
    Thanks for the quick reply, I'll give that a try.
    I know about the flashing light warning, but unfortunately got caught out by the 'no cash or cards' problem!
    West Midlands
    Quote Originally Posted by cont1204 View Post
    Well, tried to drain the filter and all I got was a load of gurgling and nothing coming out. Took a while to start and won't keep running.
    Tried to let water out again, more gurgling and nothing.
    Gurgling suggests air to me. Maybe I should try bleeding?
    Jeff.
    Regular Member keefy*2010's Avatar
    Jul 2010
    Grain, Rochester,Kent
    Vehicle : Vectra C Facelift
    Engine : 1.9Cdti 150
    Dti engines. Unfortunately if you have emptied the fuel filter in the engine bay then you have to prime them as they have no electric pump in the tank.
    The diesel injector pump has to pull the fuel through the filter from the tank if the is air in it you could damage the pump .
    West Midlands
    Replaced fuel filter, topped up filter with DERV, cleaned the boost sensor which looked like a half chewed black fruit pastille, bled off and off she went!
    Thanks guys, good work!
    Jeff.
    Wirral
    10 Post(s)
    Engine : 1.9CDTi
    Mileage : Lots
    No worries, glad you got it sorted.
  1. 2.2 direct fuel pump and fuel pressure regulator
    By w111y in forum Engine & Drivetrain
    Last Post: 11th July 2012, 22:12
  2. HELP!! My car goes like a kangeroo at start up!!
    By leeoliver in forum Engine & Drivetrain
    Last Post: 19th March 2011, 12:22
  3. Fuel housing sensor/fuel temp senser a
    By sri adi in forum Vectra C / Signum Car Chat
    Last Post: 2nd July 2010, 10:15
  4. Fuel pressure sensor/fuel pump failure list following Watchdog investigation.
    By happychappy in forum Vectra C / Signum Car Chat
    Last Post: 14th January 2009, 13:18
