Results 1 to 3 of 3
Thread: Electrics Help
    Default Electrics Help
    Hi
    Haven't posted for a while, to busy lurking I guess.
    I have 2003 Signum 3.2 Elite and have a problem with the drivers side window/mirror/locking control. Started with the mirror control not working in down direction, will not control drivers or passenger side so not mirror problem. The window button on drivers side is also playing up.
    Is this unit serviceable? I have seen them on ebay but they do not have the switch to control front and rear windows. How much do they cost new? or any one know of an Elite being broken anywhere?
    This morning the drivers side seat adjustment has stopped working. Could it be related to the dodgy switch? or what fuse to check?
    Not related to the above but have had the car nearly a year and have only had two problems, oil cooler failure and inlet manifold crack. I have also ditched the tyre pressure monitors as they seem to loose pressure and the metal valves break. More hassle than they are worth.
    28 mpg averaged out over 15 000 miles (have joined the 100000 mile club), mainly town driving with a bit of motorway. The other half does most of the driving and must tickle the throttle because i get no where near this MPG!
    Dunstable
    Try this for the window switch mate http://www.vectra-c.com/forum/showth...witch+contacts
    or one on ebay if you want to replace it http://cgi.ebay.co.uk/Vectra-C-Drive...item1c1760213f
    Try cleaning the contacts first as above though, is a common problem.
    Thanks for the reply, you are a star.
    Feel a bit daft as I tried to search but did not find those.
  1. tow bar electrics
    Last Post: 22nd November 2012, 13:39
  2. electrics
    By charlotte in forum Electrical & ICE (including SatNav)
    Last Post: 9th May 2012, 00:33
  3. Electrics????
    By GRANTY in forum Electrical & ICE (including SatNav)
    Last Post: 10th March 2011, 02:45
  4. 2.2 dti sri All electrics gone???
    By ShaneK in forum Vectra C / Signum Car Chat
    Last Post: 16th May 2010, 14:34
  5. Tow bar, which electrics?
    By Supersport2 in forum Electrical & ICE (including SatNav)
    Last Post: 8th June 2008, 12:24
