Thread: Servicing info wanted please
    Kingston Upon Hull
    Default Servicing info wanted please
    Hi all
    My car is a Vectra c DTI sri 1,9 150
    what i would like to know is what oil and what make of oil people use
    also what kind of job is it to do the oil and fuel filters
    We use Millers oil at work for our vehicles Diesel engines would that oil be ok to use ?
    thank's Jacko
    PS is there any other jobs i should do when doing a service
    J
    As long as the oil meets or exceeds GM-LL-B-025 (as its a diesel) and is SAE 5W-30
    then it will be fine. What should be done will be listed in the service book somewhere as it depends on the mileage/age of the car.
    Bristol
    Vehicle : CDTI 150
    Every 12mths/20K replace oil and filter, drain water from diesel filter
    Every 24mths/20K replace pollen filter
    Every 48mths/40K replace air filter and diesel filter
    Every 24mths regardless of mileage replace brake fluid
    Every 60mths regardless of mileage change anti freeze
    In reality I change oil and filter every 6mths/10K
    Air and pollen filters 12mths/20k
    Fuel filter 24mths/40K
    Brake fluid every 2 years.
    Oil filter is awkward even on a ramp, requires 32mm socket and sits at the rear of the engine low down.
    Diesel filter can be fun...Pain to get out of the crash box and the lid can be tight, see how 2 section. On the plus side it has a 'lift pump' so no problems with bleeding the system afterwards.
    Sweden
    Castrol say to use Edge 0w-30???
    13 Post(s)
    Quote Originally Posted by Jabbekot View Post
    Ignore what Castol suggest. Vauxhall recommend that you use 5w/30 long life fully synth oil in ALL Vectra-C engines.
    Bristol
    Vehicle : CDTI 150
    Cant imagine why Castrol would recommend one of their own oils!!!!
    Manufacturers and oil companies spend a lot of time developing oils.
    Indeed there are at least 10 different 5W30 fully synthetic oils.
    Exact ingredients depend upon SAPS properties, long life ability, fuel economy etc.
    Oils that meet the GM spec have been approved for use specifically within Vx engines to meet the design requirements.
    Gone are the days of one drum of oil suits all cars.
  1. wanted some laptop info
    By hoochydady in forum The 'Off Topic' room
    Last Post: 24th March 2011, 23:18
  2. Help finding servicing info please
    By Wilco in forum Vectra C / Signum Car Chat
    Last Post: 6th April 2009, 17:22
  3. wheels wanted and info
    By andysara in forum Vectra C / Signum Car Chat
    Last Post: 26th February 2009, 23:05
  4. SRi/GSi dash etc info wanted please
    By Jay in forum Styling
    Last Post: 15th November 2005, 23:06
