Results 1 to 3 of 3
Thread: Auxiliary drive belt squealing
    Regular Member James C's Avatar
    Essex
    Engine : 2.8 Turbo
    Default Auxiliary drive belt squealing
    Now the colder weather is here my auxiliary drive belt has started squealing intermittently. It’s only doing it when the engine is totally cold and has no load on it, and the weather is either cool & wet or very cold. As soon as the engine is up to temperature or you put some load on it the noise goes away. The only exception has been once or twice when it’s been near freezing when it’s really squealed like a pig (rather than an annoying squeak) as I first pull away. Back off the throttle and it goes away never to return that trip.
    I’m wondering if this means I only need to adjust a tensioner, or if I need the whole belt & tensioner replacing? Is it a DIY job, or are there any special tools required? My mate’s a mechanic, so I might be able to borrow anything special from him. Rather not have to take it to a garage with Xmas looming. Oh, the car’s an 03 Signum 3.0 CDTi V6.
    Mine did the same, I just replaced the belt and it never squeaked again (while I had it). I got the garage to do it, only paid for the belt as they messed it up the first time by saying they had one in stock, kept the car all day and then found out it was one for a 1.9!
    Essex
    Engine : 2.8 Turbo
    Anyone know if this is DIY or if it needs any special tools please?
  1. Auxiliary Drive Belt Diagram
    By den2712 in forum Engine & Drivetrain
    Last Post: 5th April 2012, 02:17
  2. Auxiliary Belt Y20DTH?
    By Thom in forum Engine & Drivetrain
    Last Post: 14th September 2011, 18:29
  3. Auxiliary belt squeak!
    By Croxley in forum Engine & Drivetrain
    Last Post: 1st June 2010, 21:06
  4. Squealing Noise from drive belt area
    By RobW in forum Engine & Drivetrain
    Last Post: 22nd April 2010, 15:51
  5. Auxiliary belt
    By Graham in forum Vectra C / Signum Car Chat
    Last Post: 6th February 2008, 20:20
squealing fan belt vauxhall signum
3.0 cdti squaking belt
