Thread: ECU software version
    Regular Member clightowler's Avatar
    Oct 2007
    Leeds
    Trim : SRI hatch
    Engine : z19dth
    Mileage : 110000
    Default ECU software version
    Can anyone tell me the latest software version to use on a 1.9cdti 150, its a 56 plate Vectra, or at least what the year odf the software release is, I mine is 2004 which is probably the original release, is there a later map of the engine management programme?
    Thanks all
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Im still on my original software from new'ish, I had 1 update roughly 12/18 months from new (04 rg), if the cars running ok i wouldn't worry, i only had mine in because it had a rare steering fault that was very very unknown within vx! (it tried to throw itself off the road, elec steering pump threw a mega wobbly), if it aint broke don't fix it kinda thing would be my advise!, there wouldn't be any real need for an update unless you were having issues.
    Oct 2007
    Leeds
    Trim : SRI hatch
    Engine : z19dth
    Mileage : 110000
    it just seems a bit hesitant when accellerating, EGr clean swirl flaps working (cyl 4 a bit worn but otherwise ok) and no other faults showing. my bro in law has an elite estate with same engine and it seemsa lot nippier than mine.
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Try cleaning the boost sensor & throttle body!, when doing the throttle body check the circuit board for oil ingress & the solder joints, there will be a guide for these in the 'how 2' section.
  1. CID into non CID version
    By Rennie in forum Electrical & ICE (including SatNav)
    Last Post: 26th September 2011, 07:45
  2. Radiator - Swap an Auto version to a Manual version?
    By dae36 in forum Engine & Drivetrain
    Last Post: 27th January 2010, 17:26
  3. op-com software version for 1.9 CDTI
    By Marco_ita in forum Electrical & ICE (including SatNav)
    Last Post: 4th August 2008, 17:28
  4. cr1 150bhp version
    By fellie in forum Parts for sale
    Last Post: 15th December 2007, 12:27
  5. Z20NET Software version & PPC
    By TechWolf in forum Petrol Engine related
    Last Post: 26th January 2006, 21:48
