Thread: help needed shudders comeing up through steering wheel
    Regular Member sri adi's Avatar
    Jan 2010
    ireland
    Default help needed shudders comeing up through steering wheel
    hi guys i recently put new steering rack in my vec not long after putting it in im getting wild shudders through my steering wheel anything over 50mph i was told it was my wheels and tried 3 different wheels and it tll der cud it be a dry joint or wud it be dwn to the steering rack
    Jan 2010
    ireland
    Bump has anyone came across this or what cud it be
    Central Scotland
    Seems a bit strange this is happening after a new rack has been fitted, although it could be coincidence.
    Tech2 or opcom the EHPS and CIM, if no faults are found and live data is fine, check tyre balance/pressures/CV's etc.
    Jan 2010
    ireland
    Ya I'm to check my cv joints to see if they dried out can't think of anything else my flywheel is gone wud this hav any affect
    woking
    Iv also got this goes away after 100 though lol
    Jan 2010
    ireland
    mine is ok up to 50 and then im like a human vibretor steering rack go mental
    preston
    sounds like wheel balancing to me. have you changed tyres recently?
    if so have you swapped fronts to rear and vice versa
    that works for me
    ireland
    just an idea,i cleaned my dash last month,pulled steering wheel to get behind it etc,driving that evening,it seemed to be bouncing when i drove,try adjust the lever that adjusts the steering wheel height,worked for me,worth a try anyways
  1. New steering wheel control needed SMD conversion gone wrong
    By chuckleuk in forum Electrical & ICE (including SatNav)
    Last Post: 9th November 2011, 21:18
  2. hello there my engine shudders
    By mase56 in forum Introduce yourself.
    Last Post: 18th January 2011, 22:30
  3. Advice Needed - Steering Wheel Vibration
    By Fozman in forum Suspension, Wheels & Brakes
    Last Post: 1st August 2010, 22:48
  4. help needed with steering wheel
    By davidjameswest in forum General Chat
    Last Post: 8th April 2009, 22:10
  5. Steering Wheel stereo wires needed ?
    By CdRsKuLL in forum Electrical & ICE (including SatNav)
    Last Post: 9th June 2008, 23:03
