Results 1 to 10 of 18
Thread: CD70 & Heater Control
    Regular Member Mick B's Avatar
    North East
    Default CD70 & Heater Control
    Just a daft question .I have just put my CD70 and CID in the car (took out CD70 with GID)and all was working well untill yesterday.I noticed no power to my climate control and it didnt illuminate with the rest of the dash.This was working when I set off and has done this a couple of times today.It either works or doesnt.I have read all the heater issues and I have none of the issue with water resitors half working on no2 etc. Are the CD70 harness and the climate control panel linked. Could I have disturbed something when fitting the CD70 and colour screen.Turning the ignition off for 10 odd minutes usually rectifys the problem.I have spoke with my father in law who owened the the car from new and he has never had any issues.
    Any ideas fellas.
    Full Member Robsey's Avatar
    North East Cheshire
    30 Post(s)
    Trim : Energy
    Mileage : 150,000
    I would suggest that the DIS (display) has not been programmed in the variance coding to show that the heating system is via ECC.
    You may need to also program the mid speed CAN of the DIS to also show the ECC as "present".
    The Audio pass code will not be required for anything that does not involve the immobiliser or security settings.
    On odd occasions, you may need to change the code index... but the exact number configuration illudes me at the moment..
    The options are dependent upon programing system
    Diesel or petrol
    With / without add-on heater
    With / without Ice Crystal warning
    With without Board computer.
    and obviously specific vehicle... Vectra-C, Astra-H, Zafira-B and so on.
    PM sent per your query..
    North East
    Cheers for all that fella. Also the PM you sent was blank. So basically I need a tech 2 session to get the ecc linked to the screen. Is this something a vauxhall tech can do or is it going to hard work explaining it all. Also I have freind with a snap on diagnostic computer will that be able to sort it.
    Also the car is a Signum,3ltrV6 diesel Elite and it had everything through the screen sat nav monochromatic display if that helps.
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Vehicle : Insignia
    Trim : Dynamic
    Engine : 1.6 turbo
    Year : 2019
    Mileage : 44000
    Well as robsey writes.. then yes CID and ECC is linked.
    if its a matter of codeindex or variant code i dont know.
    North East Cheshire
    30 Post(s)
    Trim : Energy
    Mileage : 150,000
    Quote Originally Posted by Mick B View Post
    PM re-sent... for some reason it was initially blank..
    I then re-sent it, but it came back to me...
    PM has now been re-forwarded, and appears to be correct
    North East
    Robsey cheers for the very professional advice on the above issue and pointing me along the correct path. Sorting things out with Tramman after he offered his services(and he's closer)
    So fingers crossed all will be resolved soon
    Thanks fellas
    North East Cheshire
    30 Post(s)
    Trim : Energy
    Mileage : 150,000
    It is my pleasure - only too glad to help where I can..
    Also love the footer comment... I'll have to learn to dance.
    Regular Member henryf's Avatar
    Oct 2007
    Hollola / Finland
    I have same kind of problems. Please give some commects how things are going on.
    North East Cheshire
    30 Post(s)
    Trim : Energy
    Mileage : 150,000
    Quote Originally Posted by henryf View Post
    Have you changed your display, or any other modules recently ?
    Or have you done anything to the car recently ?
    It will help with choosing the best diagnosis
    Oct 2007
    Hollola / Finland
    I swap CD30MP + GID to CD70 + CID (paired and i didn't make tech2 treatment) then problem began.
  1. heater control flaps
    By keithv1 in forum Vectra C / Signum Car Chat
    Last Post: 22nd December 2010, 19:19
  2. Heater control
    By mitch in forum Vectra C / Signum Car Chat
    Last Post: 10th November 2008, 18:10
  3. heater control panel
    By daviek in forum Bodywork & Interior
    Last Post: 13th October 2006, 21:09
