Results 1 to 10 of 10
Thread: Adjust Clock/Time Manually after installation of Replacement Head Unit
    Nov 2010
    Scotland
    Angry Adjust Clock/Time Manually after installation of Replacement Head Unit
    I recently bought a Kenwood system to replace my crap CD30. Everything is fine and I still have the trip computer controls on the steering wheel. However, now that the clocks have changed I cannot change the time on the display as I can't use the settings that were on the CD30. Also, I don't have the buttons near the display to manually adjust the time either. Is there another way to adjust the time manually or am I going to have to take out my kenwood and connect my CD30 again just to amend the time.
    Your help would be much appreciated as it is driving me mad.
    Cheers
    Dave
    Regular Member SRimonkey's Avatar
    Mar 2009
    wednesfield
    lol leave it, it`ll be right again in 6 months........unless you get a stalk with buttons for bc then puttin ya old stereo back is the only way unless ya can get it to reset usin rds radio stations
    Blantyre
    I have the same issue with the CD30 and i aint changing the clocks again,
    New Member Badger Quintero's Avatar
    Sep 2010
    Nr. Oxford
    I just put the old unit CD30 back in, only takes 10 mins...............
    May 2009
    South West
    Can be done with tech2. My local dealer would do it for free as a good will gesture because I had my annual service and mot with them. But, others have been known to charge full wack.
    Worth asking!
    Nov 2010
    Maidstone
    Change your loom adaptor to this (Connects 2 CTSVX002) and alows you to access time and date change via steering wheel.
    Jan 2009
    Londonderry
    Hold the left scroll button on the steering wheel and change it through that menu. You don't need any steering adapter as you are accessing the car screen not the headunit
    Blantyre
    Quote Originally Posted by cdti_sri View Post
    Doesnt always work mate, i had the same unit, facelift and mine also doesnt work like that , so 6 months of the year its wrong
    Regular Member blue estate's Avatar
    Feb 2008
    oh well.. I tried..
    Why not just disconnect the battery at midnight? Thats all i did
    Feb 2008
    oh well.. I tried..
    Worked this out as it was bugging me!
    Left control on steering wheel.. using the lower button of the 2.. push and hold will get you in the menu.. then use scroll wheel to select date/time
    After that im sure you can work it out as i forgot lol
  1. replacement head unit
    By stefan in forum Electrical & ICE (including SatNav)
    Last Post: 25th January 2012, 22:56
  2. New head unit and time date and BC
    By Rob12 in forum Electrical & ICE (including SatNav)
    Last Post: 11th October 2011, 19:22
  3. Touchscreen Head Unit replacement
    By jacko39 in forum Electrical & ICE (including SatNav)
    Last Post: 30th November 2009, 00:16
  4. Clock adjust
    By johnny1983 in forum Vectra C / Signum Car Chat
    Last Post: 28th October 2009, 18:12
  5. Head Unit replacement
    By falco in forum Electrical & ICE (including SatNav)
    Last Post: 19th December 2007, 11:01
https:www.vectra-c.comforumshowthread.php123144-Adjust-Clock-Time-Manually-after-installation-of-Replacement-Head-Unit
change time on cd30how to change time on vauxhall zafira 2010setting astra clock 10 platewhat happens to clock change radio vauxhall cd30zafira b set clockset time on board computer astra hzafira b change radio cant set timezafira b change clockastra change clock with androidboard computer opel set timechange time astra 2007zafira clock adjustSetting time in cd30 mp3how to set time on astra h without radiohow to change time on vectra c with after market radioset time opel cd 30how to set the time and date Cd30vectra cant use board cumputer after changing stereoopeé cd 30 clock syncvectra cant use board computer after changing stereo site:www.vectra-c.comopel astra h 2005 set clockCd 30 set time dwtereset corsa d date and time without original radio headhow to set time display in Holden Astra
