Thread: Boot clunk/rattle/knock
    Regular Member slinky270306's Avatar
    Aug 2010
    Devizes
    Default Boot clunk/rattle/knock
    Not sure if anyone else has this issue but talk about frustrating i mean like seriously frustrating.
    The seems to be a clunk/knocking sound in the boot which sounds like its coming from the top of the rear window.
    I know i need a plastic bracket/clip for the parcel shelf but its almost as if one of the hinges is knackered. I've taken off the trim around the boot lining, cleared the boot out and still no joy but the odd thing is it only rattles and makes a noise when its cold weather. Strange i know but its bizarre. Even got the missus to drive whilst i sit in the back and i just cant pin point where its coming from?
    Anyone else have this issue or have any suggestions what it could be?
    slough
    top anti roll bushes mate.......
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Quote Originally Posted by slinky270306 View Post
    take it out for a ride again & push your fingers between the boot & hatch near the lock area!, its common for the boot lock to 'rattle' & many time people have spent lots trying to find this, If this is the case remove the plastic trim & drop the lock catch down 1/2 mm thats all.
    Jul 2012
    Hi I have this problem too. I think it's the boot lock. Any one no how to sort this. I do know I have a bush away on the kinda bent control arm at the rear. Would this be causing it.
    South east
    Yes, change the bush or the whole arm before you look for any other possible causes. If you change just the bush, don't buy the cheapest one you can find, it'll fail in a week.
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 167340
    Quote Originally Posted by ronaldodg9 View Post
    info from previous thread
    http://www.vectra-c.com/forum/showth...r-control-arms
    http://www.vectra-c.com/forum/showth...ment-Made-Easy
    Jul 2012
    Yeah thanks I ordered 2 new arms yesterday of the net for 35 so a will c how they do.
  1. Rattle, Knock & Dodgy Clutch Pedal - CDTI 120 - HELP!
    By Vaux-Man-G in forum Engine & Drivetrain
    Last Post: 29th September 2010, 19:15
  2. Front suspension rattle/knock
    By damian s in forum Suspension, Wheels & Brakes
    Last Post: 24th January 2010, 16:47
  3. clunk / knock when braking?
    By ks246 in forum Suspension, Wheels & Brakes
    Last Post: 13th March 2009, 09:55
  4. Knock/Clunk when taking up drive Rev/Fwd + Squeak from Front N/s ??
    By DeanF in forum Vectra C / Signum Car Chat
    Last Post: 6th January 2008, 18:40
  5. Clunk/Rattle Inside door
    By GaryJ in forum Vectra C / Signum Troubleshooting
    Last Post: 28th January 2007, 02:36
vectra c boot hinge rattle
vectra c boot rattle
