Results 1 to 10 of 13
Thread: poor mpg any help appreciated
    Regular Member mrk's Avatar
    Vehicle : vectra hatchback
    Trim : improving
    Engine : 1.9cdti mas remap
    Year : 06
    Default poor mpg any help appreciated
    cdti 150 averaging 40 mpg over a tank full (i've not got mpg display)mainly 2 runs a day about 12 miles each work and back ,morning average 55mph evening traffic all the way just thought 50 mpg plus would be achievable any ideas?
    Newport (Shropshire)
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    Not enough miles? takes 5 miles to fully warm the engine up.
    Oct 2006
    Waterloo, Liverpool
    26 Post(s)
    Trim : SRI VX-LINE NAV
    Engine : 1.5T (165)
    Year : 2018
    Mileage : 25000
    Half of those miles are done each way before the engine is fully warmed up. So on that basis 40mpg is about right.
    Go on a long run mostly motorway and A-roads and you'll see the difference.
    slough
    Default poor mpg
    at 2000 rpm when you are pulling away is there a flat spot then woooosh off you go? if so your swirl bars off mate....
    Aug 2010
    Antrim
    I do a similar daily commute, and average 42mpg, so yours sound about right to me. Just averaged 52.3mpg on a long 551 mile journey. As has been said short runs are not the best test of a deisel.
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    You cant expect big miles from short /stop start journeys with a 1.9, but it wouldnt harm someone with the knowlege of the common faults of these giving it the once over. 'not your local monkey' it needs inside info from a fellow owner. or if your spanner wise look at the 'how 2' section for cleaning the boost sensor, EGR, & REPAIR YOUR SWIRL BAR FOR A £1 (if its fell off). using bp ultimate or shell v power is good too.
    Aug 2010
    Antrim
    I couldn't recommend BP Ultimate or Shell v Power. They are so much more expensive that they would have to produce a huge increase in mpg to be worth while. A test by the AA indicated if anything, MPG was reduced when these 'premium' fuels were used.
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    Quote Originally Posted by WilliamLX View Post
    I tried the V power, out of interest/curiousity, didn't notice them MPG but car seemed a bit smoother on it. Been back on normal Shell (all the nearby garages are Shell) for a month or so, usually put injector cleaner through as well.
    Aug 2010
    Antrim
    I should say this was for premium deisels and premioum petrol used in standard cars. Many higher performance cars need higher octane petrol because that is how they are set up. My Octavia vRS with the 1.8T (180) enigne needed 98 fuel to run properly.
    I'm sorry, I thought you said higher performance engines
  1. your help would be most appreciated
    By bigbow in forum Bodywork & Interior
    Last Post: 14th November 2012, 23:41
  2. any help appreciated....................
    By coopey in forum Vectra C / Signum Car Chat
    Last Post: 5th July 2011, 18:10
  3. Anyone used these/advice appreciated
    By Bullylad in forum Vectra C / Signum Car Chat
    Last Post: 2nd November 2010, 16:40
  4. Help appreciated
    By mickyg in forum Vectra C / Signum Troubleshooting
    Last Post: 14th May 2010, 15:51
