Thread: What watt? solder iron for SMD conversion?
    Jul 2009
    The Rift, Cardiff
    Default What watt? solder iron for SMD conversion?
    As title, can anyone tell me which the best wattage soldering iron is to use on dash smds? I've got the smds for the clocks, stereo and heater controls ready to be done.
    I did the int. light assy buttons with blue and white but the white ones look pale yellow, not much of an improvement. I think i'll just do the steering wheel controls all blue.
    Cheers Bill
    Jul 2009
    The Rift, Cardiff
    bump
    milton keynes
    You need a temperature controlled one , one that doesnt adjust is going to cause you problems , if not now in the future.
    Jul 2009
    The Rift, Cardiff
    Cheers kman. I dont want to fluff it up and cook anything. The irons i've got are not suitable, ones almost antique and the other is a small gas one. So with a temperature control iron what temp is best?
    Cheers Bill
    milton keynes
    Thats the thing , for different things different temperatures , when I do a conversion I probably change the temperature 10-15 times depending on what I am working on.
    Regular Member Aikon58's Avatar
    Englandshire
    Vehicle : shatch- sports hatch
    Trim : cheap plastics
    Engine : metal
    Year : 1901
    Mileage : 999
    I use a 15 watt soldering iron myself for smd's,not had a problem with it because of heat saturation either,i changed the colour to blue in my ncdr1100 head unit when i had it,and they are not so common to find,so if it burnt out the pcb i would have been knackered,lol
    Worcs/Staffs/Westmids (ish)
    It's not clear cut unfortunately.....
    You need a temp regulated iron with the highest wattage possible.
    The reason for this is because when you apply heat to a component or PCB it drains heat from the iron, the larger the component/PCB the more quickly it drains, this can make melting solder almost impossible until the whole device has heated..... But the problem here is that your putting over 200 degree's (typically 250+) into a component that shouldn't be heated this much.
    A high wattage iron won't loose much heat to dissipation (because it will compensate more quickly) and you'll be able to melt the solder before transferring too much heat into the part.
  1. Solder
    By beat275 in forum Electrical & ICE (including SatNav)
    Last Post: 9th February 2012, 21:18
  2. No solder- glue?
    By Reevo in forum Electrical & ICE (including SatNav)
    Last Post: 7th December 2010, 21:21
  3. you have seen iron man now meet iron baby
    By hoochydady in forum The 'Off Topic' room
    Last Post: 8th June 2010, 13:34
  4. How the hell do you solder...
    By Dan_BlackSRi in forum The 'Off Topic' room
    Last Post: 2nd April 2009, 10:32
