Results 1 to 10 of 16
Thread: used car purchace, problems on drive home
    Nov 2010
    manchester
    Default used car purchace, problems on drive home
    Hi new on here just got my 1.9cdti (secondhand) on the drive home noticed clutch was very low and tended to be sticky/crash into gears more so going up tho the gears)had to let revs die down to get into gears with out crunching them,tickover seemed lumpy and slow (almost to the point of cutting out) more noticable when you depressed the clutch(also got a noise like thrust bering gone or goosed.also whilst driving the whole car seemed to vibrate,plenty of power there when you gave it some but the whole vibrate thing has got me a bit worried,It's a nice car(04 with 100k on clock)any ideas? to point me in right direction as to where to look/fix
    lanark
    6 Post(s)
    Year : 2017
    dmf/clutch/slave cylinder not a cheap or easy job..... but if you bought from a garage get it straight back to them
    Regular Member markm's Avatar
    Oct 2006
    Portsmouth
    Whole car vibration is normally the DMF/Clutch, would be looking circa £1500 for both to be changed,
    Would be taking it back if it were me
    stockport
    Exclamation
    Get it straight back to them and tell them that a mechanic friend has told you it's the DMF and that you want them to sort it,and make sure you tell them you want to SEE the old parts they have replaced.(You can't trust car dealers,even the VX main dealers have been known to pull pretty shady stunts!!).FELIXX.
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 85000
    If you bought it from a garage im sure by law they have to give you 3 months warranty, but if its from a private seller from somewhere like gumtree or out one of the advertising papers I think its sold as seen tbh.
    Nov 2010
    manchester
    Unfortunaty I bought cheap from a friend who needed help(money) quickly, new there would be faults so did'nt pay that much for it £1300, so if I can get sorted & keep cost down to 2k (inc purchace price)think it would be a bargain , dont know that much about them or what they would cost for a 2004 sri no faults,just a chance I took ,had I lent the money doubt if I would have seen it again,at least this way have something to show for it (hopefully),I have phone around after reading threds on here and found a breakers who say's he has one complete for £150,however knowing what breakers are like for sayin yes these fit (then they dont or are not even for the car you asked for)going to take the gearbox off and get the clutch bit's out so I can visualy check it the right one, befoe payin for it, I sure that I saw something about welding the springs together (or something like that) to fix the problem, anybody on here heard that one?
    and would the clutch account for the rough tickover? or is that more an injector problem (seals or whatever)
    steve
    Newport (Shropshire)
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    I have an auto but sounds to me like you may have DMF probs and likely the EGR needs cleaning. Was this a private or dealer sale?
    Nov 2010
    manchester
    private sale so no comebacks
    with the erg valve can it not be blocked off (like you do on some imports?)
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Look throught the 'how 2' section on this forum, go for cleaning the EGR, BOOST SENSOR, THROTTLE BODY, then i would check all of the injector plugs (elec conectors) remove them one by on & give them a squirt with electrical contact spray only!, this should sort most problems apart from the clutch. also look at the repair for the swirls bar for £1.
    Nov 2010
    manchester
    Thumbs up
    Ta for the info , in process of sorting clutch bits out quotes from £400 to £450 allin (do it myself not fitted) will check the posts out you stated and get on with them first, the bit I stated about welded clutch was totaly wrong seems it some new uprated 1 piece clutch but not for 1.9 (yet) gutted over that ,as would have gone for one of them as a replacement
    thanks to all who offerd help to a newbie
    steve
  1. drive me home lights
    By DAVIDD88 in forum Vectra C / Signum Car Chat
    Last Post: 21st March 2011, 02:23
  2. Help! Limp home mode after DPF problems
    By Awkward kid in forum Engine & Drivetrain
    Last Post: 4th December 2010, 15:30
  3. Scary drive home
    By johnnyallen in forum Suspension, Wheels & Brakes
    Last Post: 22nd February 2010, 20:11
  4. My drive home tonight. LMAO
    By AJA in forum General Chat
    Last Post: 24th November 2005, 08:39
