Results 1 to 10 of 11
Thread: crossovers! wheres the best place to buy? do i definatly need them?
    Liverpool
    Default crossovers! wheres the best place to buy? do i definatly need them?
    Just got myself a amp & sub, which was a great bargain!
    however still need to get a wiring kit
    I am still debating weither to wire it to the door speakers rather than fitting more in the boot!
    just wanted to know if i would definatly need to buy some crossovers for each door speak and where would be the best place to get them?
    Regular Member Knight Rider's Avatar
    Apr 2008
    Motherwell
    Vehicle : Vectra C SRi 1.8vvti
    Trim : Sri
    Engine : 18.vvti
    Mileage : 29,500
    Wire up the front door speakers with a 4 channel amp then whack the sub onto that amp too Turn up...............enjoy.
    Liverpool
    so no need for the crossovers?
    i used to have 4 6x9's and a sub run off a 1000w amp direct a while back in my focus with no issues, just dont want to start burning things out
    also would i have to dissconnect current wires from headunit to speakers?
    Apr 2008
    Motherwell
    Trim : Sri
    Engine : 18.vvti
    Mileage : 29,500
    Quote Originally Posted by paul_sri150 View Post
    Use the crossovers if you're using component speakers Paul, with the other question just snip the cable to the speakers then run them to the amp. Your best bet would be a nice set of front door speakers with tweeters and an amp in the boot. Coz you want the bass at the back of you and the higher ranges in the front.
    Club-Vaux Admin
    Engine : 1.9 cdti
    Mileage : 145k
    do a proper job, use a mono/2 channel amp to a sub then use four channel amp and run new wiring into the doors and use some new door speakers that come with cross overs.
    I wouldn't recomend using the original wiring to run off an amp its just not upto the job.
    I will be doing the above job to the vec in the coming weeks now my 4 channel amp has arrived.
    Apr 2008
    Motherwell
    Trim : Sri
    Engine : 18.vvti
    Mileage : 29,500
    Quote Originally Posted by bensterzback View Post
    Sorry matey I didn't mean to say the original wire to the amp I should have made it clearer about using good cable for the speakers. The quality of the OEM cable wouldn't do justice to the sound. I would get a seperate amp for the sub too saves overloading the 1 amp.
    Club-Vaux Admin
    Engine : 1.9 cdti
    Mileage : 145k
    I once let a "professional" car audio installer loose on my car ... who put 300w RMS through my front door wiring looms on a vec b and into a single 100W crossover.
    needles to say it melted the door loom and set the X-overs on fire burning the door cards too.... lucky it never set the whole car on fire ..
    Liverpool
    could the original speakers be used for now without crossovers until i upgrade them?
    Club-Vaux Admin
    Engine : 1.9 cdti
    Mileage : 145k
    I wouldnt amp the standard door speakers at all
    Liverpool
    Ah right ok, suppose I best hold out for after market ones then lol
  1. Wheres the best place to sell my Insignia?
    By phil67 in forum Insignia car chat
    Last Post: 28th November 2012, 20:04
  2. Replies: 11
    Last Post: 1st August 2012, 15:48
  3. Need a CH Radiator-wheres cheapest place to buy in West Mids?
    By Vaux-Man-G in forum The 'Off Topic' room
    Last Post: 9th January 2011, 20:24
  4. wheres te best place to buy egr
    By asty in forum Engine & Drivetrain
    Last Post: 23rd February 2010, 19:58
  5. Wheres the best place to get irmy chrome door pins
    By bobby-tupper in forum Vectra C / Signum Car Chat
    Last Post: 26th December 2008, 12:09
