Results 1 to 10 of 11
Thread: Wash wipe - no water
    Nov 2010
    Coventry
    confused Wash wipe - no water
    Hi I have just cleaned my filter in the bottom of the screenwash resevior as I was only getting a trickle come through - it was pretty gunked up.
    I have reconnected everything and now no water comes out.
    I took the pump out again and sat it in a jug of water with pipes and electrics connected and everything worked fine, but as soon as I connect it back to the resevoir, nothing. I can hear the pump working but no water, front or rear.
    I have an 04 Signum Elite - 2.2 dti Auto
    Any help please - I am cold and frustrated!
    Regular Member paul.sessions's Avatar
    leighton buzzard
    keep trying it sometimes take a whille to get through the system
    13 Post(s)
    Did you also flush out the tank as well? Chances are if you didn't, the filter is blocked again.
    Nov 2010
    Coventry
    been trying for a while and a I also flushed out the screenwash tank
    When the pump iw connected to the electrics and pipes and sat in a jug of water all works fine as soon as I reconnect to the screenwash tank nothing
    Nov 2010
    Coventry
    at this time of year i really need this working
    please advise
    13 Post(s)
    I take it the multiplug is firmly connected on top of the pump?
    Nov 2010
    Salisbury
    the pipes are connected up the correct way arnt they? otherwise all you will be doing is pumping air into the fluid bottle.
    Check the simple things first, pipes connected, nothing in the system blocked etc.
    13 Post(s)
    Quote Originally Posted by Lee_gsi View Post
    How did you work that one out?
    All that would happen is that the rear screen would get squirted if you tried squirting the windscreen, and vice versa if you tried squirting the windscreen you'd get fluid out the rear screen nozzle.
    Nov 2010
    Coventry
    All connections work fine when I place the bottom of the pump in a jug or water - both front and rear screens get a good soaking.
    The problem is when I put the pump back on the resevoir - no water comes out at all.
    Before I cleaned the filter the jets worked but only a trickle came out.
    Jul 2009
    The Rift, Cardiff
    Maybe the gromet is not fully in place, then when squeezing the pump housing and stopping the impeller?
  1. UPGRADE FOR SALE: Auto wash wipe sensor and mount
    By merikiito in forum Parts for sale
    Last Post: 4th February 2011, 21:32
  2. Wash Wipe Question
    By Redviper in forum Electrical & ICE (including SatNav)
    Last Post: 15th July 2009, 12:13
  3. wash wipe prob (washer)
    By SteveH in forum Vectra C / Signum Car Chat
    Last Post: 1st January 2008, 21:19
  4. Wash / Wipe stalk acting up this morning
    By ChrisM in forum Electrical & ICE (including SatNav)
    Last Post: 1st January 2008, 19:09
  5. Wipe out!
    By MysteryElite in forum Quick Photo Album
    Last Post: 11th June 2007, 11:31
