Thread: Pre Cat Removal anyone?
    Jun 2009
    Chelmsford
    Default Pre Cat Removal anyone?
    Had a new twin exit system fitted and removed cat at same time, and thats given better response, but has anyone also removed the pre cat?
    Been advised that it will give 5/10 bhp more removing this and airflow more freely, BUT will it give me any problems with EMl coming on or MOT emissions problems, believe there is a sensor on the pre cat?
    Any advice welcome, cars a 05 Vectra cdti SRi 150bhp
    Regular Member winnie2457's Avatar
    kings lynn, norfolk
    I have removed mine it's only a temp sensor in the pre cat all I did was undo the down pipe and flexi removed from the bottom of the pre cat 3 bolts then drilled a big 20mm hole right through the pre cat so it's still in situ but the internals are drilled through so it's got a nice passage for the gasses to flow through it looks standard and the sensor is still in place and I just passed a mot no probs I got 0.7 out of a fail limit of 1.5 for the smoke test well within limits
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Quote Originally Posted by winnie2457 View Post
    Do all the CDTI's have pre cats m8?
    Gazza4
    kings lynn, norfolk
    I'm pretty sure they all do and try are tucked away up next to the turbo you will only see it if you take your undertray off and follow the exhaust up and just before the turbo is your pre cat
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Cheers winnie.
    Gazza4
    Jan 2010
    Perkinsville, County Durham
    Trim : Sri nav
    Engine : Z19dth
    I had Scorpion make me one up for mine. Not had it fitted yet though.
  1. dpf removal
    By chrislloydie in forum Vectra C / Signum Car Chat
    Last Post: 6th January 2013, 10:53
  2. Tar removal
    By Jim Bob in forum Detailing and Car Care Discussion
    Last Post: 17th April 2010, 20:18
  3. Cat removal & EGR
    By Bullylad in forum Vectra C / Signum Car Chat
    Last Post: 25th September 2009, 16:58
  4. DPF removal
    By sthomson1 in forum Engine & Drivetrain
    Last Post: 16th March 2009, 17:01
  5. Tow Bar Removal
    By korlinski in forum Bodywork & Interior
    Last Post: 30th April 2007, 21:19
