Had both front and rear pads replaced at the same time is this normal for the rear 2 wear before the front ?
It is on the Vec C mate, very normal
aye vecra c . The rear discs brakes & pads were all replaced under warenty abot 20,000 miles ago becasue they were sticken on arnold clark replaced them do u fink this could be the problem again ?
The way my pads are going it seems possible to go through two set of rears on the same fronts.
its because the rears are so small, apparently. was the same for me on my old 3.0
Also the rears wear most where you can't easily see (on the inner side of the disk)
So this is common then Cheers lads
yep, worked out on my taxi 3 rears to 2 fronts, so normal.![]()
hi
i have had this problem vx told me the brake bias is 60 / 40
rather than the usaul 70/30
hope this helps
