Results 1 to 10 of 13
Thread: can someone please tell me .....
    Regular Member paul.sessions's Avatar
    leighton buzzard
    Default can someone please tell me .....
    im after the black mastic glue rubbery type of weatherproof stuff used for bits of exterior trim etc, dont know what it is or what its proper name is can someone help me please on name or where i can purchase etc... (the proper automotive stuff)
    thanks Paul..
    Vehicle : Insignia sport tourer 2.0 CDTi
    Trim : /Elite
    Mileage : 34900
    Paul have a look for tigerseal on E-bay
    and still loving it
    leighton buzzard
    cheers have you used it before, it sounds the part.
    its for the metal strip on my irmscher grill. where i took it off to paint under it, it was stuck on with black rubbery mastic stuff. i used evo stick 'serious glue' which dried flexible etc... but after a while it comes away on the irmscher end (there is less to stick to).. so am looking to find this black mastic stuff..
    Regular Member gibbon7000's Avatar
    lincs
    There's also some stuff called marineflex (ebay)
    Oct 2006
    southampton
    16 Post(s)
    Quote Originally Posted by paul.sessions View Post
    Morning Paul, how did you remove the strip in the first place. cheers Clive
    leighton buzzard
    original thread is here i just slid a 6inch steel rule behind the bit where irmscher is written and slid along very gently, every few inches there is a bit of mastic holding it onto the grill.
    Trim : /Elite
    Mileage : 34900
    Hi paul , i have not used it but i know others have used it to fix on spoilers and the like .
    and still loving it
    Wirral
    10 Post(s)
    Engine : 1.9CDTi
    Mileage : Lots
    Tigerseal is very good stuff, was common on the Corsa forums to see it used to stick on Irmscher splitters. Bit of that and you'll be fine.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    It's excellent stuff Paul, i've used it for umpteen different things, The TR7's door skins are stuck on with it. The irmy badge, rear diffuser and foglight bracket are held on with it on my car (the plastic bracket came away from the bumper)
    Oh and I used it to stick my puntos gearknob back on and it's rock solid
    leighton buzzard
    cheers guys looks like tiger seals the stuff then,, has anybody got a small amount spare????
    please
    if i bought a tube it would probably get used once then go off
