Thread: Turbo delay or issue with auto gearbox?
    Nov 2009
    Kent
    Post Turbo delay or issue with auto gearbox?
    I notice a delay when flooring the car. Is it a known issue with this type Vectra? is it the gearbox? or problem with Turbo? Or could it be a MAF sensor?
    Say when you at roundabout and flooring it, there is a small delay before it kicks in and pulls away.
    When does the auto gearbox oil needs to be flushed/changed? And how about the timing belt?
    Car is: Vectra C from 2007 1.9 150 CDTi Elite Auto and done 60k
    yorkshire
    hi read my post about haveing it remapped before i did thought was going to die at roundabouts lol
    Regular Member Aikon58's Avatar
    Englandshire
    Vehicle : shatch- sports hatch
    Trim : cheap plastics
    Engine : metal
    Year : 1901
    Mileage : 999
    Quote Originally Posted by DieselHead View Post
    I found when i unplugged my egr valve that the response to acceleration was improved,and my 1.9 cdti elite auto has just hit 63k,so while it was in for a main servive at the dealers i had the auto box fliud changed for piece of mind,the timing belt i will get done with in the next 6 months,as there is no real rush if vauxhall say 10 years or 100k for timing belts on the 1.9 cdti.
    Regular Member Chuddy's Avatar
    Jul 2009
    Derbyshire
    Vehicle : 2.8T 280 vxr
    Trim : 280 vxr
    Engine : 2.8t
    Well mines a 3.2 auto and there is always a slight delay for the auto gearbox to know you want to cane it, nothing major though
    Newport (Shropshire)
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    I've been driving auto's fpr over 10 years now, seems to partly be autoboxes, they do seem to lag a bit. You get used to putting your foot on throttle a bit earlier. The Vec also seem to have a bit of turbo lag. Doing the airbox mod helps.
    Regular Member Lao's Avatar
    Aug 2009
    Romania, E.U.
    Vehicle : Vectra C Estate Automatic
    Trim : Elegance
    Do you really floor it? I suppose you know about the little "button" in the floor, that needs to be pushed with the pedal. Still, auto gearbox has a little lag. You'll know to kick it when you need it, over time.
    Nov 2009
    Kent
    I dont literally floor it but you know what I mean about the delay/lag.
    What button in the floor?
    May 2007
    West Yorkshire
    kick down button.
    Jul 2009
    Derbyshire
    Trim : 280 vxr
    Engine : 2.8t
    basically if u push the accelerator a little furthur than all the way there is a kick down button. Although mine kicks down without the need of the button anyhow
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    Quote Originally Posted by Lao View Post
    Kickdown at a junction or roundabout pulling away, which was the OP's situation, would be fun, torque steer and wheelspin comes to mind.
    You do normally need to put foot down a bit further/earlier pulling away with an auto, the Vec seems a bit more so. Nearly caught me out a few times when I first had it, coasting up to roundabout or junction, clear, so back on throttle - and nothing happens. You get used to it. As I said, the airbox mod and a K & N filter seemed to help. On mine, V power diesel smooths it out as well, but not everybody finds the same.
  1. Replies: 8
    Last Post: 1st July 2012, 21:27
  2. Vectra C 1.8 Clutch/Gearbox issue?
    By ukmgdrooling in forum Engine & Drivetrain
    Last Post: 13th May 2011, 22:57
  3. CVT Gearbox issue Vectra C
    By Del in forum Vectra C / Signum Troubleshooting
    Last Post: 22nd February 2009, 02:53
  4. Gearbox issue or not??
    By barlos1973 in forum Engine & Drivetrain
    Last Post: 17th December 2008, 01:55
  5. 1.8VVT gearbox issue...
    By luckyluke in forum Engine & Drivetrain
    Last Post: 21st August 2008, 16:10
vauxhall signum auto delay
