Page 1 of 4 123 ... LastLast
Results 1 to 10 of 35
Thread: After fitting HID: Vectra C 1.9CDTi 150 07 engine warning?
    Nov 2009
    Kent
    Post After fitting HID: Vectra C 1.9CDTi 150 07 engine warning?
    I've got HID H& 35W 6000k fitted this morning, had to remove the airbox filter on the driver side to get in there and fit the bulb.
    After fitting everything I got a message now on the car dashboard, well its not a message but rather the known Engine Warning LED/bulb?
    Has this anything to do with disconnecting the MAF sensor and trying the lights during fitting them?
    I dont have any warning with regarding a bulb failure, did search the forums and topics with HID fitting but couldnt find anyone had issue with the engine warning light.
    Anyone could help with this? or do I need to take it to main stealer for reading/resetting faults?
    Regular Member Aikon58's Avatar
    Englandshire
    Vehicle : shatch- sports hatch
    Trim : cheap plastics
    Engine : metal
    Year : 1901
    Mileage : 999
    If you have taken the plug off from the maf and turned the ignition on while the plug is off,then it would have stored a fault with that sensor.
    Nov 2009
    Kent
    Thanks, to reset would need a main dealer? Or could local garages reset it as well?
    Englandshire
    Engine : metal
    Year : 1901
    Mileage : 999
    Quote Originally Posted by DieselHead View Post
    Someone local to you with opcom could also reset the light,it doesn't sound like a fault with the sensor,you know you took the plug off,so there is no big hurry to turn the light off,my eml light is on all the time,but thats because i have the egr plug off
    Nov 2009
    Kent
    Post
    Thanks, need to find out about OPCOM
    Nov 2009
    Kent
    When do I need to get Auto Transmission Oil changed? It got 60k on the clock.
    And how about the timing belt?
    How much do main stealers charge for Auto Oil change?
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 85000
    Disconnecting the battery for 20 minutes should clear the light.
    Nov 2009
    Kent
    Cheers,
    Just disconnected the battery will update you later on
    When do I need to get the Gearbox oil changed?
    Nov 2009
    Kent
    Disconnecting the battery for 20mins or so didnt help clearing EML.
    Engine : 1.9 CDTi
    If you do get someone to have a play with Op-Com get them to change the AFL setting to present so you dont get any errors and it will also help make the bulbs/ballasts last longer.
  1. lowering engine 1.9cdti vectra
    By Milliedog in forum Vectra C / Signum Car Chat
    Last Post: 8th September 2012, 14:11
  2. vectra 1.9cdti engine blipping
    By pud wayman in forum Vectra C / Signum Troubleshooting
    Last Post: 1st June 2012, 16:39
  3. Replies: 9
    Last Post: 7th July 2010, 14:54
  4. Engine nightmare with a Vectra 1.9CDTi 150 on a 05 plate
    By sailingthewild in forum Engine & Drivetrain
    Last Post: 23rd May 2010, 22:06
  5. Vectra 2.0 Diesel engine warning light
    By Biggus Shlongus in forum Vectra C / Signum Car Chat
    Last Post: 7th September 2009, 19:11
how to fit hid vectra c
