I've took off EGR valve and I'm trying to get the grey cover off but I've broken one clip and casing starting to crack
How does it come offand will it matter about clips and cracks ?
Irmscher Insignia CDTI 130
One clip will not matter , like i said you need to slide bits of cardboard under the tabs unless you have some one with you to hold some of the tabs open then slide it off .
and still loving it
All done boband omg you couldn't see any moving parts under there
it was full if black soot , On phone ATM but will post a picture of it up so you can all see.
Have to say it feels smoother but to me it feels not as fast in 1st 2nd seems to rev fine but gets to 4000rpm quicker but doesn't feel quicker if you know what I mean![]()
Here we go
Well cacked up that mate.
Took mine off the other week, wasnt as mucky as yours though.
Did you put some grease on the cam & plunger?
Mines done 162k lol think it was original EGR as it was stuck solid![]()
Don. That has seen better day,s "eh".
Its like new nowCleaned it with carb cleaner and sprayed loads and loads of WD40 into it.
I did boost sensor too cleaned this with a soft toothbrush and carb cleaner and took it for a blast, As i said it feels smoother but it feels like its lost powerno fault lights on at all so im confused.
Maybe its all in my head but if i damaged either EGR or Boost sensor then i would surly get a fault code
A good days work, by the look of it. I bet you are more than happy with it now.![]()
i done the same today even broke 1 clip but i never seen an egr valve so blocked up , i took a full jam jar out of it ,the car seems to be starting easier but it looks like 1 of my swirl flaps is gone the rod is there but no flap
