Results 1 to 10 of 13
Thread: How to remove lower grill
    Nov 2010
    Midlands
    Default How to remove lower grill
    Hi I have a Vectra C 53 reg, I'm trying to remove the lower grill without breaking it.
    My bonnet release is broken and I've read on here that you can reach up through the bottom grill and release it, I can see a clip but it looks like it would be secured in more than one place.
    Trying to do this without breaking it if possible, any help would be great. going to go have another go in the meantime.
    Thanks in advance
    Regular Member madman's Avatar
    nottm
    you cant reach. trust me i cut a gap in mine to try it. unless your arms are really thin and unfeasibly long.
    remove the bottom engine tray and poke a long bar up to flick the lever.
    Nov 2010
    Midlands
    Thanks, I had a look but it looks like that cover is attached to the front bumper somehow as I tried removing the screws but it won't shift.
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    The only way is to remove the bumper first and depending how long your arms are the bumper slam bar as well .
    Your lucky you dont have a dti with those you have to take everything off before you can get to the latch
    Regular Member GTS's Avatar
    Oct 2010
    Poland
    I did it in my facelifted one. U need to push palstic framework inside till all latches (is it good word?) let go and be careful not to damage air cooler. Then try to take it out from the bumper. Hope it helps
    nottm
    so the dti is much tighter then to reach up Bob? no wonder i couldnt reach. just couldnt reach up far enough, and only having one elbow joint didnt help
    stockport
    Thumbs up
    Quote Originally Posted by madman View Post
    Thats one of the problems with owning a Vectra.
    You need the ability to disarticulate joints when working on them.(I have heard,on good authority,that VX employees bring their children in on school holiday periods to do all the "fiddly and awkward" jobs!!!!).FELIXX.
    Engine : 2.0DTi
    Mileage : 73350
    If you have the original front grill then the best bet is to just break it and then get a replacement one from a breakers . But if you have one of the Irmscher ones like me then its a pain to have to remove it , i have done it three times in all and can get it done in about two hrs but to do that i have to remove the bumper ,then the bumper slam bar , i can then get my hands up behind the grill and with a small ratchet set undo the eight nuts to remove the grill , (original vx grills are fixed by self tappers).
    If you have the plasti/rubber valance,s then theonly option is to break it of at the centre point , you can then get to the release spring.
    Apr 2008
    murton seaham
    its easy took me all of 5 seconds to remove and spot light and number plate just drive up the road and look out for a phesant it will work a treat oh its took me a week to fix it
    Nov 2010
    Midlands
    Quote Originally Posted by bobssignum View Post
    I do have a DTI, which is probably why I'm having a mare trying to get to anything, weather isn't helping either.
  1. Lower Grill
    By lizard in forum Styling
    Last Post: 6th June 2011, 12:54
  2. how did you remove chrome from v grill
    By kirky2k4 in forum Vectra C / Signum Car Chat
    Last Post: 25th March 2011, 19:25
  3. How do you remove the SRi lower grill...
    By Leemarksmith in forum Bodywork & Interior
    Last Post: 25th July 2010, 11:19
  4. vxr lower grill
    By n8sby in forum Styling
    Last Post: 26th May 2010, 21:50
  5. Anyone know how to remove a facelift grill?
    By Craig1985 in forum Vectra C / Signum Car Chat
    Last Post: 18th September 2008, 19:24
https:www.vectra-c.comforumshowthread.php122966-How-to-remove-lower-grill
vectra c replacement bottom grill
