so the car is jacked up on one side, the wheel is off, the bolt that holds the... brindle, bradle () whatever its called, is nearly out.
can I remove the bolt?
will it go ping...?
what shall I do next - thanks.
will it go ping...?
I had both sides up on axle stands, the bolt just comes out, no pinging. I had to force the strap off the bush with a flat blade screwdriver.
Not to sure if it'll be the same with only one side up.
Try lifting the strap with a screwdriver to see if there's and pressure on the bolt.
