Thread: Rear door problems
    Sep 2009
    tyrone
    Angry Rear door problems
    HI,
    Want to check the best way to open a rear door.
    Have the child locks on the rear doors so the kids cant break free & now the handle on the outside has stopped working. (probably pulled handle too hard)..
    How do I open the door to get at machanism????
    NEED HELP>>>
    thanks
    Ruby
    Regular Member Innes's Avatar
    Plymouth
    Michael Cain used explosives
    If my memory serves me correctly I think the door handle pulls on a metal rod that then opens the latch. If the rod has come off the handle you may have to take the door handle off and see if you can manually pull the rod. Having said that I thing you actually have to open the door first and undo a screw to take the handle off. A bit of a catch 22!
    You may have to try to taker the door card off to get to the mechanism but doing that with the door closed would probably mean taking a hammer and chisel to it as there are 3 screws at the bottom of the door which you wont be able to access without the door open. AAARRGHH Tricky one!
    Perhaps call the dealers and ask them if they have ever done one and get some tips from them?
    Wales, UK
    Thats a difficult one Cant think whats best....
    Regular Member Craig1985's Avatar
    harwich essex
    Your gonna have to try get the door car off without opening the door. If you try removing the door seal you may be able to get to the screws at the bottom of the door card?
    Plymouth
    Hi Ruby. Did you have any luck with this?
  1. Door open light and dashboard problems.
    By misterpants in forum Electrical & ICE (including SatNav)
    Last Post: 18th October 2019, 10:22
  2. door lock problems
    By jinkie in forum Bodywork & Interior
    Last Post: 19th February 2012, 22:30
  3. Door Lock Problems
    By Dazsri in forum Electrical & ICE (including SatNav)
    Last Post: 20th January 2012, 11:29
  4. rear wah problems
    By red sport in forum Electrical & ICE (including SatNav)
    Last Post: 6th February 2011, 19:11
  5. Rear Suspension problems?
    By BigMan in forum Vectra C / Signum Car Chat
    Last Post: 23rd June 2007, 07:05
