Thread: 2.2dti fault help required
    Regular Member sberrow's Avatar
    Newport (Gwent)
    Default 2.2dti fault help required
    driving back on a long journey today i had a loss of power and the spanner light come on. i was in 5th doing aprox 60mph came to a slight hill, engine was put under load and loss of power. stopped the car. turned off ignition and left thirty seconds. Started up again this time no light and not in limp mode. however is boosting but now seems a little underpower.
    Im currently away from home and do not have much time on my hands to be putting the car in the garage. sugestions on the fault would be a great help.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    First ports of call, check for split vacuum pipes/boost pipes if there is nothing give the boost sensor/egr a clean
    Newport (Gwent)
    cheers will have a better look tomorrow
    Regular Member Innes's Avatar
    Plymouth
    Heres a pic I like to show DTI owners. It shows all the likely parts that are going to cause you trouble.
    NOTE: my blue vacuum pipes are on the right but Vauxhall quickly re-routed them to the left after the heat from the geabox was ruining the solenoids. Here is pic with them off to the left (courtesy of Jonesy):
    If you want to see more about replacing the vacuum hose view this thread:
    http://www.vectra-c.com/forum/showthread.php?t=115759
    and if you need your intercooler hose replaced try this thread:
    http://www.vectra-c.com/forum/showthread.php?t=116528
  1. poor performance z20net fault help required
    By chesh1980 in forum Engine & Drivetrain
    Last Post: 4th October 2012, 22:59
  2. p0100 Fault 2.2DTI 2004
    By 1TAYLOR1 in forum Engine & Drivetrain
    Last Post: 24th April 2012, 22:05
  3. 2.2DTI Spanner fault Light.... HELP
    By n30jjb in forum Vectra C / Signum Troubleshooting
    Last Post: 15th June 2009, 08:42
  4. vectra 2.2dti p0234 fault!!!
    By welshrugfan in forum Engine & Drivetrain
    Last Post: 17th November 2008, 13:17
  5. Info required re: chipping/tuning 2.2dti
    By rozzer1976 in forum Diesel Engine related
    Last Post: 28th March 2007, 15:45
