Hi guys, Thinking of doing a quick change, I have a 2007 1.9 cdti, can someone tell me whats the best way to drain the coolent. Any pics would be great as I am a novice.
To do a full coolant change you'll need to remove the Thermostat, or you could just remove the bottom hose on the Radiator, remove the expansion tank cap, drain, refill, run, and repeat a couple of times. Once your happy your getting clean water refill with Red OAT antifreeze. Sorry not sure how much you'll need for a 1.9 but i'd think at least 3LT's topped up with water.
Is it actually due a change yet?
I thought Vauxhall used long life antifreeze?
5 or 10 yrs spring to mind.
Someone will probably clarify shortly.
If you want to do a full flush its prob best to disconnect the top and bottom hose's on the radiator and flush the engine and rad separately to avoid any cross-contamination.
10 years im sure like most other cars, Unless you know for sure there is none there test it first it should be fine to -25 leave it well alone.
Better to make a nice cup of tea & grab a packet of dunkers with fire on full blast than be outside in this weather!!
