Results 1 to 10 of 21
Thread: Need Info on Bleeding diesel pump
    kent
    Default Need Info on Bleeding diesel pump
    My signum has got air in the system due to out of fuel i think my son did it but he said he didn't but it was low and my car is parked on quite a steep hill.
    Is there any info about on how to bleed/Prime the diesel system.
    Its the 2003 - 2.2 dti model
    Its now got fuel, I have tried starting it several times and it will start but cut out after 5 seconds or so.
    Then i have to wait about 5 minutes and it will start again but again cut out.
    I have thought about just trying to pump the fuel through by keep starting it every 5 minutes and hope it will run eventually but im a bit worried i may damage the fuel pump.
    I can't bump it either as its an auto
    Any advise would be greatfull as i cant afford to send it to vauxhall
    Regular Member viperone's Avatar
    Aug 2010
    Amersham
    kent
    Thank you so much this is so much help
    Aug 2010
    Amersham
    let me know if it worked for you as I never had to do it so far.
    Regular Member Jonsey's Avatar
    Oct 2010
    Walkden, Manchester
    Mine did this after I changed the fuel filter, but it started up after about 5 times cranking it over.
    East Midlands
    Quote Originally Posted by Jonsey View Post
    ?Did you top up the fuel filter cannister with fresh diesel before screwing back on,if you did'nt then the problem you experienced happens,so allways top up with diesel.
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Quote Originally Posted by macdad View Post
    Did you top up the fuel filter cannister with fresh diesel before screwing back on, if you didn't then the problem you experienced happens,so allways top up with diesel.
    I tried to fill up the housing before starting the car but it didn't help Had to bleed it at the injectors...
    East Midlands
    Quote Originally Posted by Celes View Post
    Ok Celes...i had that problem just once when i first got the car(not topped up) but it still started after about 5 short cranks ,maybe i was just lucky.
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    I know that's what it should do...which worries me because that happened on my 3.0CDTI not 2.2DTi!!!! The CDTi has a priming system of its own... The DTI usually doesn't even need 5 cranks...it normally fires right up
    kent
    I have tried starting my car using this method but still wont start.
    Just ended up flattening a brand new battery fully charged
    I did have fuel coming through on no4 cylinder.
    I can start it for a few seconds every 10 minutes or so then it conks out
    any idea's
    Is there a pump i can buy to bleed the diesel through
    I thought about one of the bulb hand pumps but the fittings were not the right size to fit on the fuel return hose.
    In the haynes manual it does say for the 2.0 and 2.2 ltr diesel engines that a bleed unit KM-948 electic primer or a suitable alternative.
    I did search on google but cant find the pump.
  1. Bleeding the air from the diesel fuel system
    By pete7175 in forum Engine & Drivetrain
    Last Post: 27th July 2016, 07:24
  2. Y22DTR fuel pump info?
    By lee gsi in forum Diesel Engine related
    Last Post: 28th August 2012, 22:08
  3. Diesel bleeding
    By dti111 in forum Engine & Drivetrain
    Last Post: 6th February 2011, 17:08
  4. Diesel bleeding
    By craigbarlow18 in forum Engine & Drivetrain
    Last Post: 25th September 2009, 19:31
  5. Bleeding diesel engine
    By bigbenny4gf in forum Vectra C / Signum Troubleshooting
    Last Post: 17th September 2009, 07:53
https:www.vectra-c.comforumshowthread.php122857-Need-Info-on-Bleeding-diesel-pump
how to bleed cdti diesel
how to prime a vauxhall diesel engine
bleeding injector pipes vectra c locationvauxhallopel bleeder unit km-948 vauxhall vectra bleed pumpvectra air in diesel can i bleed the diesel though return pipehow to bleed cdti diesel pumpis there a manual primer on a vectra c dieselhow to use a hand bulb to bleed a diesel fuel line opel zafira A 2.0 dtiair in the fuel system opel vectra c 2.0 dtiy22dtr fuel sysytem schematicsvectra c 2.2 fuel system bleedbleed fuel system signum diesel 2.2bleeding diesel cdtibleeding cdti using leak offhas a vauxhall insignia got bleeding pump has a insignia got fuel bleeding pumpbleedding saab diesel pumphow do i bleed a diesel fuel system on my vectravectra c diesel primerbleed opel dti dieselbleeding diesel system 09 20 l insignia
