Thread: headlight problem?
    Apr 2009
    leven, fife
    Default headlight problem?
    right here goes my problem when revving the car slightly and letting it run back to idle the headlights dim down well when i say headlights i actually mean most of the lights on the car (2003 vec sri 2.2) what could be causing this? faulty earth strap?
    helps in solving this would be great
    thanks guys
    stockport
    Arrow
    Quote Originally Posted by jungle View Post
    thanks guys
    I think you might find that with all the lights on you are using loads of power and that's what's causing the dimming.It's like they flicker/dim when you turn the steering wheel when the car is standing,thats because of the power being drawn off by the power steering.FELIXX.
    Apr 2009
    leven, fife
    any cures? diesel battery? or will i just have to live with it?
    PRESTON
    check the running voltage at the battery with engine running, lights on, hrw on, heater on, in fact anything electrical on, and see if you got 14volts, maybe early warning of alternator on the way out, in which case a bigger battery wont help. In most cases the bigger battery is primarily there for more cold cranking amps, to start bigger engines in colder weather.
  1. headlight problem
    By vvcsri in forum Bodywork & Interior
    Last Post: 29th November 2010, 02:31
  2. Self Levelling Headlight problem?
    By spoons in forum Vectra C / Signum Car Chat
    Last Post: 15th October 2010, 20:22
  3. Headlight problem
    By Keithy in forum Vectra C / Signum Car Chat
    Last Post: 30th September 2010, 17:27
  4. pre-facelift headlight problem
    By the-ferret in forum Electrical & ICE (including SatNav)
    Last Post: 15th July 2008, 20:31
  5. Headlight problem.
    By JCB in forum Vectra C / Signum Car Chat
    Last Post: 31st May 2007, 18:37
