Thread: Headlight Change for a Vectra B?.
    stockport
    Exclamation Headlight Change for a Vectra B?.
    My son has a "v" reg vectra B.He,(or I have),fitted it with an HID system.However,it seems that,because the lense system is of the reflector type,the beam pattern is scattered and he's getting grief from other motorists.Is there any way I can resolve the situation other than the obvious,ie,is there another type of headlight that would fit and not cause problems?.Thank's in advance.FELIXX.
    13 Post(s)
    You need to fit an "R" type HID bulb. The H7R has a blackout sticker on the top of the bulb.
    eg - http://www.hids4us.com/index.php?rou...product_id=120
    Mentioned in Technical Support
    See "What the difference between projector & reflector headlamps e.g. H7 and H7R" section.
    That's of course if the Vec-B takes a H7 bulb - can't remember.
    Or you could find some Vec B xenon headlights that came with the CDX and GSi models. They have the projector lenses and could probably be easily modified to take an HID kit...
    stockport
    Talking
    Yes is does,and I also like the idea from penfold,however,it depends on costings.It's like he never has any money and is always broke etc,etc etc......Everyone with children know where I am coming from......Yes?.FELIXX.
    Regular Member Cam's Avatar
    Sep 2009
    Fife
    You could get a set of FK angel eye headlights, they have projector lenses that work well with HIDs
    stockport
    Arrow
    Looked on eBay and HID's Direct do them for £15.99.so I've ordered a set.Will let you know the results when they're fitted,should do the job tho'.A big THANK'S to everyone for your help.FELIXX.
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    Quote Originally Posted by felixx View Post
    They will do the job, have these in the wifes Laguna (which have Xenons in reflectors from the factory anyway) and they are spot on.
    stockport
    Exclamation
    Thank's for that.But tell me,if xenons are not "supposed" to be fitted as OEM in reflector headlights,how do they get round the reflector lens issue?,(well,according to some of the previous posts anyway).FELIXX.
  1. Quick Headlight Change Makes All The Difference
    By Dannyboy2k11 in forum Styling
    Last Post: 15th February 2013, 06:47
  2. Vectra AFL Headlight fault?
    By Maddog1974 in forum Electrical & ICE (including SatNav)
    Last Post: 30th November 2009, 22:15
  3. Headlight change
    By Ian T in forum Styling
    Last Post: 22nd July 2008, 16:58
change headlamp vectra b
