https:www.vectra-c.comforumshowthread.php122808-Anyone-sprayed-wd40-or-plus-gas-into-inlet-manifold#::text=You shouldnt spray anything inlet manifold for that matter.&text=WD40 is mostly solvent its actual oil content is VERY low.
can u spray wd40 in an air intake,
1.9cdti spray wd40 on swirl flaps,
https:www.vectra-c.comforumshowthread.php122808-Anyone-sprayed-wd40-or-plus-gas-into-inlet-manifold#::text=Butlike Gazza saysyou of problems without realizing it.,
wd 40 clean intake valves,
Spray WD40 into air intake,
clean intake and egr wd40,
wd 40 spayed into diesel intake,
can you use wd40 to clean egr,
what would happen if wd40 got into intake manifold,
can you spray wd4p on swirl flaps,
can i spray wd40 in inlet manifold,
https:www.vectra-c.comforumshowthread.php122808-Anyone-sprayed-wd40-or-plus-gas-into-inlet-manifold#::text=Its great for cleaning carburettors or anything in the vicinity.
