Thread: 17" steel rims to fit Signum 1.9 cdti
    Nov 2010
    Lincoln
    Default 17" steel rims to fit Signum 1.9 cdti
    This may seam like a stupid question// but do vauxhall make a 17" steel rim I could use to replace the space saver?
    I was caught out recently with a blow out whilst towing. The space saver was ok - but I realy needed a rim of similar size to the alloys on the car.
    Failing that, does anyone know a sensible place to get hold of a single 17" standard signum alloy please?
    I'm a new member to the forum, liking what i see .
    Cheers.
    Wirral
    10 Post(s)
    Engine : 1.9CDTi
    Mileage : Lots
    I'm not sure they make steel wheels of that size. They may well stop at 16" however you could get an identical wheel from somewhere like Ebay if it's only to be used as a spare. What model do you have?
    Regular Member GTS's Avatar
    Oct 2010
    Poland
    You'd have to find steel 5x110 17"s and fit some wheel caps. Unfortunately this cannot be taken from Insignia because of screw distance (5x120). U need to seek some aftermarket wheels because as I know there are no Vx originals.
    Regular Member Craig1985's Avatar
    harwich essex
    i got a brand new spare steel wheel with brand new tyre out of a vec b from scrappy for £10, 16" but better than that space saver
    13 Post(s)
    I didn't think a Signum could take a full sized spare in the tyre well?
    Only the hatch and saloon Vectra. IIRC.
    Newport (Shropshire)
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    Local VX dealer told me the way to go was a 16 inch steel wheel with a non low profile tyre, reckoned that would work out same radius. I had asked about a new 17 inch facelift SRi alloy, came to over £100 for one, just the wheel
    Garthorpe
    what wheel are you after I have a 17" wheel listed in the for sale section might be of some interest to you
    Nov 2010
    Lincoln
    Cheers for all the help - i did wonder if vauxhall made a 17" rim to fit a signum - have been searching with no results/ I have a 1.9 cdti Signum on a 56 plate, all standard set up etc. I assume a 16" will fit past the callipers, i'd just have to up the profile to match the other wheels & tyres. Have my eyes on a rim on Flea bay
    Greg, how much are you asking for the 17" rim? not sure on the spec of my alloys, i'll have a look 2moro for the PCD sizes etc.
    Cheers.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    All vec-c/signum wheels are interchangable
    All that really matters is the style of wheel (if that bothers you)
  1. For Sale: Vectra-C/Signum SRI 17" Alloy Wheels (set of 3). RIMS ONLY, NO TYRES.
    Last Post: 6th September 2012, 15:15
  2. For Sale: 3 x 16" Structure Steel Rims (no tyres or trims)
    Last Post: 15th September 2011, 09:07
  3. Steel Rims
    By snowball1 in forum Suspension, Wheels & Brakes
    Last Post: 16th October 2009, 21:46
  4. Vauxhall Signum 2.2 Dti. 20" rims, irmy bits.
    By freks in forum Cars for sale
    Last Post: 20th March 2008, 19:31
signum 17 steel wheels
