Results 1 to 10 of 27
Thread: stalk problems dont work v6 cdti sri vectra
    Nov 2010
    derby
    Exclamation stalk problems dont work v6 cdti sri vectra
    hi im new to this site and was wondering if any one could help i just have brought a v6 vectra cdti sri lovely car was not to sure about auto but am ok with it the only issue i have is that the stalks dont work cruise control on left hand side and on the right hand side say I logo which i thinks means info click them both nothing really annoying as i have just brought this private can anyone shed any light on the problem fixable ??
    Do the indicators work?
    If so, then the stalk is connected and it is just the cruise control needs sorted
    Before moving off, press the foot brake
    Now try the cruise control
    I am not aware of an "I" logo on the right hand side
    Mine has a four position variable switch on the top for the intermittent wiper, only works when the wiper selector is in position 1
    Nov 2010
    derby
    yes incators work as well do lights when you pull back on stick towards you as for the i logo mines on the face on the stick the right stick and the top of the stick has the wiper options and a little wheel left to right
    Nov 2010
    derby
    wipers ok to what did u mean by it works when in postion 1 what works???
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Vehicle : Insignia
    Trim : Dynamic
    Engine : 1.6 turbo
    Year : 2019
    Mileage : 44000
    The buttons on the wiperstalk is for the BoardComputer controls (there are 3 buttons on it)
    Nov 2010
    derby
    yes i have got this one do i need to remove them and clean connections
    Regular Member david.aka.judas's Avatar
    Suffolk
    pull the rubber gator back and you'll see a small groove, push a straight paper clip into the groove and the stalk can then be pulled out.
    once its out clean the contacts and unclip the two clips and place a small piece of card under the contacts - this ensures the contacts are in permanent contact.
    then push it back and see if it works.
    then pull the clutch lever up with your foot to see if that works if the stalk hasn't fixed it. if that works its the clutch return spring.
    if neither works, buy a warranty and try a claim for a new cim pack....lol.... its about £400.
    mine is the same and thankfully, its covered by warranty.
    Nov 2010
    derby
    what do u mean by buy a warranty and is the stalks a common fault?
    Nov 2010
    derby
    p.s its a auto
    Suffolk
    just to make sure - its your cruise control thats not working???
  1. Making BC work with stalk controls
    By paulvectrac in forum Electrical & ICE (including SatNav)
    Last Post: 17th April 2019, 14:09
  2. stalk problems still dont work v6 cdti sri vectra
    By v6 sri diesel in forum Vectra C / Signum Car Chat
    Last Post: 10th December 2010, 11:56
  3. vectra c stalk problems (not working)
    Last Post: 29th November 2010, 21:36
