Results 1 to 10 of 23
Thread: Upgraded Radio won't turn off automatically?
    Regular Member Thom's Avatar
    Nov 2010
    UK
    Default Upgraded Radio won't turn off automatically?
    I have a JVC cd player in the veccy with the steering wheel controls connected up via autoloeads wiring.
    The problem is now we've connected it all i have to manually switch it off every time i turn the car off.
    Any ideas how i can fix this?
    Thom
    Regular Member Keithy's Avatar
    Jan 2008
    Dundee
    cross over the red and yellow power wires so they go red-yellow and yellow-red
    Nov 2010
    UK
    I think that's what we've done to make it work in the first place mate because it wasnt originally. i'll double check!
    Thom
    Jan 2008
    Dundee
    Are you using the autoleads steering control lead also?
    Nov 2010
    UK
    Yeah both the patch kit and the other part required, both suited to the radio and car, however my original wiring does appear to have been somewhat butchered - however doesnt appear to be causing any problems appart from this perhaps!
    However radio worked perfectly before we installed this new wiring.
    Jan 2008
    Dundee
    Ahh i had a similar problem when installing the patch lead. You have to add another wire the the plug iirc. For the life of me i can't remember where to put it. I will keep searching
    Nov 2010
    UK
    Cheers mate, i really appreciate the help as little things like this really REALLY annoy me!
    Thom
    Jan 2008
    Dundee
    There is a white and orange wire on the plug. Connect the red wire to that and it will work
    Jan 2008
    Dundee
    Look at this thread. i'm sure this was the method i used and it worked http://www.vectra-c.com/forum/showthread.php?t=92012
    Nov 2010
    UK
    Cheers mate, ill give that a try at the weekdn!
    Thom
  1. Turn off auto radio?
    By Rab in forum Vectra C / Signum Troubleshooting
    Last Post: 26th January 2014, 19:27
  2. My Radio Will Not Turn Off CD30
    By JACKALG1 in forum Electrical & ICE (including SatNav)
    Last Post: 8th February 2011, 00:25
  3. Radio comes on automatically when switching on ignition....
    By waterbourne in forum Vectra C / Signum Car Chat
    Last Post: 7th January 2010, 22:19
  4. Indicators not automatically cancelling
    By 5ft10ins in forum Electrical & ICE (including SatNav)
    Last Post: 2nd July 2008, 22:30
  5. Radio won't turn on without display?
    By Merick in forum Electrical & ICE (including SatNav)
    Last Post: 29th March 2007, 21:36
