Results 1 to 10 of 19
Thread: Wing Mirrors Not Operating Correctly
    Regular Member maz's Avatar
    Lincoln
    Question Wing Mirrors Not Operating Correctly
    I have already replaced the Window/Mirror control module in the drivers door but problem still exists.
    When the button for the left electric mirror is pressed, the controls work fine, however, when the switch is pressed for the right mirror as soon as i press any of the dirrectional arrows it moves both the left and right together...... How and why?
    Any help greatly appreciated.
    Robin
    WGAF#5
    pssst.
    dont tell anyone else but its supposed to do that... as per the handbook
    hope you can get a refund on the control you replaced as its not needed
    and welcome to the forum
    Berkshire
    29 Post(s)
    Vehicle : Toyota
    Trim : Yaris Hybrid
    Engine : 1.5 Hybrid
    Year : 2021
    Mileage : 5525
    Robin has been a member since 05 ...member number 359 one of the earliest.....
    you should of found that out by now lol ..as Dez said hope you can get a refund..
    Lincoln
    Never done it before!?! Always been left switch for left mirror and right switch for right.
    lanark
    6 Post(s)
    Year : 2017
    Lincoln
    Yeh.... long time member, even bought another vecci so i could stay loyal to the club.
    Berkshire
    29 Post(s)
    Vehicle : Toyota
    Trim : Yaris Hybrid
    Engine : 1.5 Hybrid
    Year : 2021
    Mileage : 5525
    Quote Originally Posted by maz View Post
    how long you had the facelift one ??? ,i,m just wondering if the preface didn't do it .
    Lincoln
    Had facelife since Nov 2006. It has always been the same till now.
    Quote from handbook:
    Adjusting exterior mirrors:
    Four-way switch on driver’s door
    Press switch for left or right hand mirror:
    four-way switch operates the
    corresponding mirror.
    Lincoln
    Are we all thinking this might be a common problem now?
    13 Post(s)
    My 53 reg (registered Jan 2004) didn't do it.
    My 06 reg (registered July 06) operates both mirrors when the drivers one is selected.
    I think it's been mentioned on here that the configuration can be changed via Tech2 so each mirror can independatly be operated if you so wish. It really doesn't bother me as I rarely alter the mirror settings as I'm the only driver of the car. It is handy when parking though as you can lower both mirrors at the same time to see the white lines, and put them back to the same setting afterwards without having to change the switch over or alter each one separately.
    You must have an very old handbook. Here's the difference between what a 2003 and a 2004 handbook says.
    As quoted from the 2003 user manual,
    Adjusting exterior mirrors: Four-way switch on drivers door
    Press switch for left or right hand mirror: four-way switch operates the corresponding mirror.
    and a 2004 online users manual
    Adjust exterior mirror
    If the drivers side mirror switch is pressed, the four-way switch adjusts the drivers mirror and the passengers mirror, and if the passenger mirror switch is pressed, only the passengers mirror is adjusted.
    This says the same thing in my Mar 2006 handbook.
  1. Wing mirrors
    By L11Marc in forum Electrical & ICE (including SatNav)
    Last Post: 4th December 2009, 23:01
  2. Electric mirrors not working correctly
    By deanos in forum Vectra C / Signum Car Chat
    Last Post: 12th August 2009, 00:43
  3. Wing mirrors
    By test_uk in forum Vectra C / Signum Car Chat
    Last Post: 5th March 2009, 19:08
  4. Wing mirrors
    By mspvxr in forum Vectra C / Signum Car Chat
    Last Post: 17th July 2008, 08:55
