Results 1 to 10 of 15
Thread: why does light switch contol unit push in ?????
    Regular Member embo's Avatar
    stoke on trent
    Default why does light switch contol unit push in ?????
    my signum light switch cluster goes in wards on a slide ,even the light switch knob pushes in ,anyone tell me why ,i had to take pannel off under steering wheel and pressed the light switch and it all slid backward ,but carnt figuire out why ???????? regards mick
    slough
    Default light switch
    thats how you remove the switch check the how2
    cambs
    if you push the knob in and turn the knob to the right(as if your turning the lights on)and pull.
    it the way it releases the switch from is housing
    West
    as above... in order to remove the unit
    stoke on trent
    ha ha did have trouble getting it out ,trying grt the screw above it ,,,well you learn summit everyday thankyou
    North West - Assistant RO Woody's Avatar
    May 2012
    North West (Warrington)
    240 Post(s)
    Vehicle : Vectra C 3.2 Elite Estate Auto Facelifted
    Trim : Elite with loads of "Extras"
    Engine : 3.2 Z32SE
    Mileage : 94,000
    Hi Guys. Have removed the dash trim ready to fit the cubby trim, but I cannot remove the light switch. I can get it to move (turning lights on full and pressing the switch in hard, but although the unit moves backwards as if to come out, it stops moving after about a centimetre and it's like I'm hitting a brick wall, it will not slide right out.
    What did I miss ?
    A really quick answer would be fantastic because as said, dash is out and don't really want to put everything back before I have to go out.
    Woody
    Grantham, Lincolnshire
    63 Post(s)
    Trim : SRi (Rather Modified)
    Engine : 2.0T Maptun (240bhp)
    Push the knob in hard BEFORE you turn it. Turn it to side lights whilst holding it in and then the whole assembly will basically just slide out.
    May 2012
    240 Post(s)
    Engine : 3.2 Z32SE
    Mileage : 94,000
    Cheers Ian, you're a STAR Next problem though is the unit pops out from the front and means I need to unplug the wiring loom from the switch, again, something that doesn't want to budge
    63 Post(s)
    There's a small catch you push in on the plug then an arm that moves down (the catch is holding the arm in place). I'll see if I can find a pic anywhere.
    May 2012
    240 Post(s)
    Engine : 3.2 Z32SE
    Mileage : 94,000
    Cheers for that, I'll go take another look and see if I can figure it
    EDIT - Found it
    Damm, what a "clever" little plug n socket arrangement. Damm I'ld have bust this without your help LOL
    Thanks again m8 , much appreciated
    Woody
  1. CD 2005 Head Unit Won't Switch Off
    By alembicbassman in forum Electrical & ICE (including SatNav)
    Last Post: 22nd March 2010, 18:51
  2. Removal of switch-unit
    By Hirobofly in forum Vectra C / Signum Car Chat
    Last Post: 16th November 2007, 15:15
  3. Light knob push????
    By korlinski in forum General Chat
    Last Post: 14th June 2007, 10:37
  4. Drivers door switch unit (windows, mirrors etc) dismantling Q.
    By MadOnVaux! in forum Electrical & ICE (including SatNav)
    Last Post: 19th December 2006, 20:09
vectra light swich wot dos it do
https:www.vectra-c.comforumshowthread.php122723-why-does-light-switch-contol-unit-push-in
