Results 1 to 3 of 3
Thread: Slave cylinder dodgy?
    Chelmsford
    Default Slave cylinder dodgy?
    Am I correct in thinking that a faulty/worn slave cylinder could be the reason why the biting point on my clutch is constantly changing?
    The clutch doesn't tend to slip (if you ignore the normal clutch judder problem on the early petrol models when cold), but I'm finding that the biting point varies at times.
    It's the original clutch, with 73k on it so it's a little worn, biting point is usually where I expect it, about half way up. Oddly, sometimes it seems to bite lower, or higher than that...
    Slave cylinder problem? I've heard a few people on here talk about replacing them
    Chelmsford
    Ok, I might have confused myself...
    Just looked at a few other posts, seems the clutch master cylinder and slave cylinder are 2 separate things... Am I right?!
    Vehicle : Jaguar XF 2.2 Sport LE
    Trim : leather
    Engine : 2.2 d
    Yes the master cylinder is close to the clutch pedal and the slave cylinder is inside the bell housing
  1. Clutch + DMF + master + slave cylinder
    By Bobsta in forum Engine & Drivetrain
    Last Post: 9th November 2012, 23:33
  2. slave cylinder
    By dr1v3r in forum Engine & Drivetrain
    Last Post: 25th August 2012, 17:37
  3. cheap dmf , clutch and slave cylinder
    By samngeorge1985 in forum Engine & Drivetrain
    Last Post: 5th May 2011, 21:17
  4. Suspect clutch slave cylinder
    By kman247 in forum Engine & Drivetrain
    Last Post: 17th December 2009, 17:24
  5. Clutch Slave Cylinder on 2.0 DTI
    By cp123 in forum Engine & Drivetrain
    Last Post: 22nd December 2008, 21:45
