Thread: Accelerator cutting out - is it meant to?
    Oct 2010
    BANBURY
    Default Accelerator cutting out - is it meant to?
    Having done a lot of trouble-free miles in the Signum (150) I encoutered my first long haul jam on the A34 last Saturday. Took approx 1 hours to move 6 miles. On several occasions the spanner came on in the dash. When I next tried to move forward there was no response from the accelerator pedal, put foot down but the engine kept idling away. It was not untill I turned the ignition off and restarted did the accelerator respond again as normal. This happened maybe 4/5 times.
    I'm skint so can't afford to take it to dealer. Any ideas?
    Oct 2007
    Shropshire
    I have no idea sorry but over the 3-1/2 years I have had it my car has thrown tons of wobblies. I wouldn't worry about it as a one-day occurance. If it becomes regular perhaps then take it further....
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Follow the 'how 2' for cleaning the EGR & BOOST SENSOR also cleaning & checking the throttle body wouldn't go a miss, all these can be done free apart from buying some carb cleaner (highly recommended) you can most certainly reuse all gaskets as i have done this many times , just take your time removing the parts & you'll be fine, dont forget when you have the EGR removed clean out the small hole where it fits onto the manifold (the hole in the manifold itself) this always gets blocked up with sooty crap.
    Nov 2010
    Vectra land
    Throttle pertentionometer? excuse spelling. would make sense on being ok after ignition turned off and on.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Quote Originally Posted by jono m View Post
    It will be the throttle position sensor, mine done the same thing. Common fault on earlier CDTI's. I would say this is your problem:
    http://www.vectra-c.com/forum/showth...45#post1338145
    Get the codes read and I won't be surprised if fault code P0638 turns up.
    Gazza4
  1. what is my GSi meant to idle at
    By Mark-R in forum Vectra C / Signum Car Chat
    Last Post: 14th November 2012, 16:37
  2. What is this meant for please?
    By 123rado in forum Engine & Drivetrain
    Last Post: 26th August 2012, 19:43
  3. how are my calipers meant to dry in the rain!?!?!?!?
    By vectra_c_wannabe in forum Vectra C / Signum Car Chat
    Last Post: 24th July 2009, 16:08
  4. wtf!! jails not meant to be this good
    By m20_swe in forum General Chat
    Last Post: 3rd January 2008, 17:45
  5. Today was meant to be THE day.....
    By The Doc in forum Vectra C / Signum Car Chat
    Last Post: 5th April 2006, 09:18
