Results 1 to 3 of 3
Thread: steering fault
    Nov 2010
    derby
    Default steering fault
    Hi. I ive got a 1.8sri vectra on a 56 plate. When turning the steering to the right everything is ok, but when turning left the steering goes very heavy and when stationary two hands are sometimes needed to the wheel to the left. I have checked all the electrical connectors on the pump, ok. Checked the fluid level, ok, but was a bit burnt. Drained and replaced the fluid and fault still present.all the suspension seems to be free. Wondered if anyone has heard of or had this fault. The pump and resevoir is mounted on the rack.
    Regular Member embo's Avatar
    stoke on trent
    has it been damaged .eg hit kerb etc .had one like this but on different car turned out rack was bent on n/s making it hard to turn one way ,,hope this helps regards mick
    Nov 2010
    derby
    No mate. As far as i can see everything it ok, no bent arms and everthing is ok.
  1. Steering Fault
    By ftm100 in forum Suspension, Wheels & Brakes
    Last Post: 26th July 2012, 20:24
  2. Steering Fault
    By samboy143 in forum Suspension, Wheels & Brakes
    Last Post: 21st May 2012, 21:16
  3. Steering Fault
    By AOL in forum Vectra C / Signum Troubleshooting
    Last Post: 9th January 2010, 18:41
  4. Steering fault
    By Steven in forum Vectra C / Signum Troubleshooting
    Last Post: 22nd December 2007, 18:20
  5. Steering Fault
    By biglardyboy in forum Vectra C / Signum Car Chat
    Last Post: 3rd December 2006, 18:21
