Results 1 to 10 of 25
Thread: CDTi Oil?
    Jun 2006
    Lake District
    Vehicle : Vauxhall Insignia
    Engine : CDTi 160
    Mileage : 53.000
    Default CDTi Oil?
    My Dad's CDTi 150 has just been in for service and i saw on the invoice they had used 10/40 semi-synth oil....now i was under the impression the CDTi's were very oil specific, using a 5/30 (or whatever it is)....or is that just for the ecoflex servicing?
    The car will be serviced at the same time every year regardless of mileage and also gets an oil change half way between services, so the oil is never left to get old and thick.
    My question is, is 10/40 safe to run in the CDTi, or will it cause issues?
    Regular Member se4's Avatar
    Aug 2010
    wales
    Sure vx put 5/30 fully synthetic in mine so would like to keep it the same, i mean it's not as if the engine is a critical part of the car? lol
    PRESTON
    Handbook lists 5/30 fully synthetic, this is more critical on the estate cars or any Vec fitted with and auto transmmission, as these have DPF's fitted.
    South Wales Assistant Regional Organiser davidjameswest's Avatar
    llantwit major
    the service should be done using 5-30 fully syn and should be done every 20 k but i used to do mine once a year min.id go back and tell them that you want the oil flushing and correct oil as per vauxhall and per autodate which nearly every garage uses
    Aug 2010
    Derbyshire
    I've got enough of this oil 10/40w semi GM oil in the garage for three oil changes. Used to own an Omega. Was told it's ok for the CDTi so long as you don't follow the 20k service schedule. So I intend to change mine with this for the next few changes, every 5k.
    Mick
    stockport
    Exclamation
    Quote Originally Posted by MickAP View Post
    Mick
    I wouldn't worry about it,if you are going to change the oil every 6 months.I had the same argument with my main dealer and it seems that they routinely use 10-40 semi on higher mileage cars,after "06", on 12 monthly service schedules.
    Really,it's a case of either or,if you know what I mean.Sometimes,if the car has always had 10-40 semi in it,putting 5-30 fully synth,which is a very thinner oil,can cause gunge and varnish type crud,which has built up over the years,to break loose and cause problems.
    Also,there's the possibility of your turbo seals being breached when using a thinner oil. FELIXX.
    Jun 2006
    Lake District
    Engine : CDTi 160
    Mileage : 53.000
    Quote Originally Posted by se4 View Post
    Yeah i understand that, but surely having the timing belt changed on time is more critical than oil grade, or not?
    Quote Originally Posted by barney490 View Post
    Well it is an estate....hmm
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Do not use 10/40 semi if you have a dpf fitted!, without dpf you can use 10/40 or even normal 15/40 diesel oil of no less grade than B3, obviously reducing changes for lower grade oils.
    stockport
    Exclamation
    Quote Originally Posted by MadOnVaux! View Post
    If your estate is fitted with a DPF,the 5-30 Fully synthetic oil will be more beneficial to use as it holds all the crap/soot that diesels produce,in suspension better than a thicker oil. It will mean that your DPF will not get clogged up as quickly.If you have a DPF fitted and the car is "06" or later,then the dealer needs to change it without charge. FELIXX.
    Regular Member Daywalker's Avatar
    Aug 2007
    Mitkunai k, Kaunas raj
    Vehicle : VW Jetta
    Trim : SE
    Engine : 1.4 TSii
    Year : 2017
    I use 10/40 semi syn but change every 10k or sooner, 2.2DTi before anyone asks lol
  1. Weird noise from Signum CDTI 1.9 CDTI (150)
    By oneightycd in forum Diesel Engine related
    Last Post: 22nd June 2007, 22:27
  2. CDTi 120bhp Vs CDTi 150bp
    By bennyk in forum Diesel Engine related
    Last Post: 6th December 2006, 23:45
  3. CRD2 Tuning Box for V6 CDTi or 1.9 CDTi
    By The Doc in forum Parts for sale
    Last Post: 20th October 2006, 21:51
