Results 1 to 10 of 18
Thread: clunk from autobox 2007 elite diesel
    dover
    Default clunk from autobox 2007 elite diesel
    i have a 2007 elite 150 diesel 6 speed auto high miles as im a private hire driver just lately it seems to give a clunk as it drops into neautral when stopped with foot on the brake and also as it as it rengages to pull away its not to bad but feels to be getting worse could it be an engine mounting as the car drives faultlesly and the box changes fine, only really noticed it as was stopping and starting in a major traffic jam now getting paranoid lol
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    And the gearbox oil was last changed when?
    dover
    been in touch with 2 autobox rebuilders and they said changing oil will not fix any problems and dont recomend it as it shouldnt need changing conteray what people say on here also been told same bye main vauxhall agent said you will be throwing 200 quid down the drain so who knows what to do for best reguarding oil change. think it may just be worn engine mount as when takeing in and out of gear the engine semes to move quite a lot
    Regular Member WeDesign's Avatar
    Jun 2006
    Vectra-C.com
    Engine : CDTi 150
    Year : 55
    I had a notchy gear change back last year, took it into my local VX DEALER for a transmission fluid change for £90 and it sorted the issue out.
    You can listen to as many people as you like BUT until you actually have it done for yourself and it cures the issue it makes you wonder do a lot of the people actually know what they are talking about.
    I have a few colleagues who swear by changing the fluid.
    Regular Member nibblitz's Avatar
    Jul 2010
    Buckinghamshire
    Of course gearbox rebuilders might say oil change wont fix it, they want to rebuild boxes... Im pretty sure VX say its 100k before auto oil needs changing... You say you've done high miles, over or under 100k?
    Oct 2009
    Bilbao&Madrid
    Vehicle : Opel Signum
    Trim : Cosmo
    Engine : 3.0 CDTI Z30DT
    Quote Originally Posted by nibblitz View Post
    In fact it says 50k... mine's (in a 3.0 Cdti) started doing funny things at 60k: changing fluid sorted the problem. Anyway, only 3 litres out of 7-8 are drained and refilled in each change.
    Nov 2010
    Wales
    I have a similar issue with my 1.9 cdti club 150 diesel estate. When I change from Reverse to Drive (or vice versa) there is a noticeible delay (maybe a second or two) and then a clunk before the gear engages. This has developed in the last 3-4 months.
    Has anyone ever had anything like this? If so, was there a solution? I'm told a new box is going to cost me well over £1k.
    dover
    Default update
    Well took the plunge and changed oil in box just over 3 liters so just under half of what it holds. And it's like a differant car so smooth and no clonk at all going to run it for a week and change again
    Regular Member mozzer99's Avatar
    bristol
    Quote Originally Posted by ramsgate View Post
    Ahhh.... it gives me a warm feeling when the 'experts' are wrong and you fix it for virtually nothing. This is a great site for those who have had problems and KNOW how to fix it by personal experience
    Regular Member Vectra Meldrew's Avatar
    Hertfordshire
    Sounds like a good result with that Ramsgate, keep us updated with how it goes.
    Did you just change the first load of 3 litres that came out or did you drain it again?
    BTW how many miles has it done?
  1. clunk on my autobox
    By corby-boy in forum Engine & Drivetrain
    Last Post: 4th September 2009, 21:45
  2. 3.0 CDTi V6 Elite Autobox problem
    By zimzunga in forum Engine & Drivetrain
    Last Post: 23rd April 2009, 18:16
  3. autobox fault on 3.2 vectra elite
    By bryn in forum Engine & Drivetrain
    Last Post: 14th August 2008, 13:38
  4. Cheap 2007 2.8T V6 Elite
    By SJG in forum Vectra C / Signum Car Chat
    Last Post: 27th July 2007, 21:09
  5. 2007 Vectra Elite
    By vectralad in forum Vectra C / Signum Car Chat
    Last Post: 4th April 2007, 19:13
