Hi could you please tell me what tyre pressure should I have as the manual I've got doesn't say about my type of engine
Many Thanks
The tyres are Michelin Energy Saver 205 55 16 (not sure you need that info)
Many Thanks
Mine vectra wagon cdti 120 said 2,3 all around with 3 people load.
You can run her at 36psi all round, this is the pressure VX say to use for max fuel economy.
Its correct, but tires will tear more at the midle.
Tbh, i have run my estate at 36psi for the last 10 months and covered 6000 miles and no noticeable wear in the centre of the tyre. Tread depths across the tyre are pretty consistant.
I have the same spec motor and run at 36psi all round, no noticeable wear out of the ordinary here either
The one that you can download from HERE probably will.
it depends alot also on wheel size, bigger wheels, mean more psi's, 16" 34psi front, and 33 rear ftw!!!![]()
